Re: Fuel Lines - measured by ID or OD?
[Re: WyleECoyote]
#1178386
02/14/12 05:58 PM
02/14/12 05:58 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
pipe is outside - hose is inside
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: WyleECoyote]
#1178388
02/14/12 11:16 PM
02/14/12 11:16 PM
RapidRobert
a piece of hard line shoved into a length of neoprene fuel line. Easy way to remem is the part that touches the other piece is where it gets measured. The "OD" of the hard fuel line touches the "ID" of the neoprene line
[Re: RapidRobert]
#1178389
02/15/12 08:40 AM
02/15/12 08:40 AM
Posts: 10,732 North Dakota
6PakBee
North Dakota
Tubing is OD X wall thickness Pipe is ID X schedule Hose is ID
[Re: RapidRobert]
#1178391
02/15/12 12:27 PM
02/15/12 12:27 PM
dogdays
NPT is talking about the threads, National Pipe Tapered is how I remember it. Pipe is described by a nominal size and schedule. The wall thickness is the "schedule" and probably has to do with a pressure rating because it increases as pipe diameter increases. For example, 1" pipe is 1.315" OD. Schedule 40 wall thickness is 0.133". Schedule 80 is 0.179". 4" pipe is 4.500" diameter. Schedule 40 wall thickness is 0.237" Schedule 80 is 0.337".
Over 12" diameter, pipe is OD x wall thickness.
Metallic tubing is OD x wall thickness.
It's handy to have a couple of books around when you're doing this stuff. R.
[Re: dogdays]
#1178392
02/15/12 02:21 PM
02/15/12 02:21 PM
6PakBee
North Dakota
There are a number of caveats with pipe sizing. In addition to the concept of schedule there is also a 'Standard' (STD) weight which for the most part is schedule 40 up to 12". Larger STD sizes have a constant wall thickness of 0.375". There is an 'Extra Strong' (XS) which is usually schedule 80 up to about 8" before it changes. There is also an "Double Extra Strong' (XXS) which usually has a thicker wall than schedule 160 up to about 8". And dogdays is right, up to 10", Schedule 40 ID is the nominal ID of the pipe. 12" is an oddball. 14" and above the OD of the pipe is nominal size.
Can you tell I do this for a living?
[Re: 6PakBee]
#1178393
02/15/12 03:11 PM
02/15/12 03:11 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, your fuel lines are 5/16 main supply, if you have a return its 1/4
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 6PakBee]
#1178394
02/15/12 05:12 PM
02/15/12 05:12 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Me too...I'm sitting at my desk at the steel pipe company right now...
