Re: De-shrouding valves?
[Re: JohnRR]
#1178237
02/14/12 11:42 AM
02/14/12 11:42 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Find two sacrificial valves...put a head gasket on the head and scribe/mark a line where it needs to be opened, unshrouded, etc. You will see what I mean. Leave the valves in place as you do your grinding/cutting.
I found an article on either hot rod or car craft, cant remember which.
You working on the IE heads?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: JohnRR]
#1178238
02/14/12 01:05 PM
02/14/12 01:05 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
What head gasket are you running now and do you have quench ?
Haven't picked a head gasket yet, but i'll most like run the factory fel-pro blue, The quench is not great, around .060"-.065", I was going to install a .061" gasket to lower it to 10.3, but that'll just make whatever quench i have worse, plus those MLSs are 160.00
There Dart iron eagles, 64cc chambers, pistons are FTs with 4 valve relieves, sit around .025" below.
Just for the record, this is a sbc 406
[Re: Von]
#1178239
02/14/12 01:10 PM
02/14/12 01:10 PM
joedust451
super gas
super gas
Branson, Mo.
Will do.
