Re: Intake Manifold Mystery
[Re: AndyF]
#1178067
02/14/12 01:09 AM
02/14/12 01:09 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Andy, that intake work is a dyno test i would love to read about. just that with no other changes
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1178070
02/14/12 12:25 PM
02/14/12 12:25 PM
Posts: 31,061 Oregon
AndyF
I am planning on getting my 514 back on the dyno in order to run that test. I have a few other things to test at the same time.
[Re: AndyF]
#1178071
02/14/12 01:19 PM
02/14/12 01:19 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
there are a bunch of things going on in that plenum. There are 3 worth mentioning. 1. Is distribution...getting 4 carb bores to supply 8 intake runners. not to mention the odd locations and geometry forced by the intake runner window where it enters the plenum. that is why you see those dividers, its to coerce distribution. then you have to factor the multiplicity of carburetors that could be used to install on to the intake plenum flange...that dictates the intake flanges shape has to accommodate all of them thats why the shape final looks the way it does...this creates the next issue.. 2. Is boundary layers..At the interchange of the carb flange and the intake base mount is some void areas that create dead spots. these dead spots are different depending on who's carb is bolted on top.. The intake manifold has to accept many different carb plates.So that dictated the shape of the plenum entry and base shape.. is a compromise from/for a mass produced part. You can custom shape the carb base on the intake to perfectly fit your carb's base architecture/shape..this is done to minimize the boundary and dead or turbulent areas directly under the carb.. This issue also brings to light the #3 which is "Coanda".. Those factory bulges under the carb matting surface are to create Coanda.. to pull the air on the roof of the runner into the runner. its very effective..think of it exactly like the short turn on the floor of the intake runner on the heads.. those bulges in the intake manifold plenum are there to maximize coanda When you go to a 4500 carb base..this "bulge"area is "in the way.. so its removed..but its removed due to architecture and not because the material or shape is corrupt..its removed because its physically in the way of a 4500 carb bore. if there was enough material outside of the dimensions of the 4500 base shape...you could include or keep it..and you would see benefits.. However there just isnt any material left in the upper plenum to include this shape..so its remiss you can see it clearly in the pictures..
sometimes and in fact often spacers show improvements..but i feel its a mask of another symptom ...the spacer allows time and distance for the after carb air to "find its way into the runners and distribute based on intake pulse. and or velocity changes..
its a partial remidy or band aid thats used because its an easy fix..but its not the best fix..
you want good clean transitions from carb plate architecture to intake plenum architecture. and you want some coanda built in on the roof of the intake tracks as they meet the plenum. and you want smooth radius-ed dividers to begin to segregate.. The cheap easy band aid improvement to all this is volume...just make the plenum a little bigger so the air has room to figure it all out based on demand...and it will reach the intake runner. but its not the best way to dont confuse the two issues...its easy to make that conclusion because spacers seem to show gains.. but you have to understand what the problem was or is...fwiw. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: reknapp52]
#1178072
02/14/12 05:13 PM
02/14/12 05:13 PM
BradH
The mods shown to the plenum on this Victor 440 intake were worth about 10 HP on a 600 HP 440 over an unmodified Victor tested back-to-back on PRH's dyno.
It wasn't simply an increase in plenum volume, either, since adding a 1" open spacer to the unmodified intake still didn't show the same gains as the plenum-ported intake w/o a spacer. The only mods to the intake are what you can see since I didn't even bother to port-match the intake at that point.
