Thanks brother!
quote]Start with the local pro paint shop. Stuff that someone says works in Seattle (wet, cool, sea level) probably isn't the best here (dry, hot in the summer, 4600').
Follow the spec sheets that come with the materials.
Do test panels!!!
Try different techniques on each panel so you know what is the best for your style.
Since you said Black with clear, block the whole thing one more time!
Make sure to lay on enough clear to cut and buff after!
There are a ton of videos on you tube from everyone from the manufacturers to Larry's other brother Darryl.
There are sites and forums for body/paint.
Thing is, there are so many different ways to get the end result that it can get confusing. Try to pick a few trusted sources and go with that.
