Can I get paint to stick on my al. radiator?
#1177979
02/13/12 09:05 PM
02/13/12 09:05 PM
Posts: 12,144 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My aluminum radiator is not real shiny anymore. I think that I would just as soon have it black in the hope that it would look a little nicer and be easier to maintain that look.
So, what (if any) process could I use to get paint to stick. Should I use a light dusting of primer? And what paint should I use?
I know I need to limit the build-up. And I would prefer to stay away from rattle can paint. I would prefer some good paint that I can spray from a gun.
Looking for good tips and tricks.
Thanks!
Master, again and still
Re: Can I get paint to stick on my al. radiator?
[Re: DaveRS23]
#1177981
02/13/12 11:22 PM
02/13/12 11:22 PM
Posts: 9,847 MI, usa
dvw
MI, usa
Thanks!
I paint all my aluminum parts. Wheels,radiators,heads,intakes. No problem with adhesion at all. Actually it sticks better to aluminum than cast iron. Clean it with scotch brite pad,prime with etch or epoxy and spray. Here's a cross ram that is even bondoed. it's still on a buddy's car 10 years later Doug
[Re: 70VcodeCoronetRT]
#1177985
02/14/12 11:33 AM
02/14/12 11:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
did your original brass radiator come painted?
I would say it depends on what kind of paint you use. regular spray paint, you should be ok.
if you use a ceremic based, engine paint, I could DEFINITELY see that affecting the heat transfer rate of your radiator.
I painted the aluminum radiator in my Dakota. flat black, then laid a stencil on it, and sprayed the Mopar "M" in blue paint over top of that.
looks good when the hood is up, and I don't notice any problems keeping the engine cool.
**Photobucket sucks**
[Re: Challenger 1]
#1177987
02/14/12 11:45 AM
02/14/12 11:45 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I believe painting them black helps them absorb heat better.
You would think it is bad but we did a test here at work on one of our transmitters and the parts mounted out where it would get hot were painted black to help them handle the heat .
[Re: DaveRS23]
#1177989
02/16/12 01:23 AM
02/16/12 01:23 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Good tips on this. Thank you.
