Help computing dish volume
#1177505
02/13/12 01:01 AM
02/13/12 01:01 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Looking for help computing dish volume. The dish will have a radius of 1.6 inches, and approx .040 deep. Thanks for any help.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Help computing dish volume
[Re: Von]
#1177506
02/13/12 01:32 AM
02/13/12 01:32 AM
Posts: 2,091 Delray beach, Florida
Performance Only
is that a round dish with straight walls and no radius at the bottom edge? (not likely) or a D shaped dish?
machine shop owner and engine builder
[Re: Von]
#1177508
02/13/12 02:17 AM
02/13/12 02:17 AM
Posts: 4,213 New York
polyspheric
New York
You're describing a shallow cylinder. The volume is the same as any other cylinder: R^2 × H × Pi, then × 16.387 to get cc from inches. 1.60" × .040" = .322", or 5.3cc
Boffin Emeritus
[Re: polyspheric]
#1177509
02/13/12 03:06 AM
02/13/12 03:06 AM
Von
NE Oklahoma
You're describing a shallow cylinder. The volume is the same as any other cylinder: R^2 × H × Pi, then × 16.387 to get cc from inches. 1.60" × .040" = .1024", or 1.7cc
Thanks for the info. I couldnt remember the conversion factor to get to ccs from inches.
By the way, I come up with 5.26 cc?
[Re: Performance Only]
#1177510
02/13/12 03:06 AM
02/13/12 03:06 AM
Von
NE Oklahoma
The piston(s) do not have a dish in them. I am needing to cut a dish in them to lower the compression. Trying to approximate the dish volume.
[Re: jamesc]
#1177513
02/13/12 02:01 PM
02/13/12 02:01 PM
polyspheric
New York
Ooopps! Thanks, calculator bit me again. Fixed it.
If at all possible, the dish should be contained entirely in the open area of the chamber - not under the quench surface.
Boffin Emeritus
[Re: jamesc]
#1177515
02/14/12 12:50 AM
02/14/12 12:50 AM
polyspheric
New York
The calculator in question is the one under my haircut...
Gimme some slack, I waved at Harry Truman when he was President.
Boffin Emeritus
