70 challenger under coat #1177423
02/12/12 09:24 PM
02/12/12 09:24 PM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
i was hoping to under coat the under side of my challenger what is the best way. what to use. thats please help
Re: 70 challenger under coat [Re: GardnersGotCudas] #1177424
02/12/12 09:31 PM
02/12/12 09:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The stuff Resto Rick or Frank Baldason sells is very much like the factory stuff and it works very well.
Are you trying to make it look like it did from the factory?
Did you car come with optional full undercoating?
Do you have pictures of the underside of your car showing where it was originally? Or is most of it still on the car?
Re: 70 challenger under coat [Re: autoxcuda] #1177425
02/12/12 09:36 PM
02/12/12 09:36 PM
Shippensburg, PA
Shippensburg, PA
try to look factory wheel house and the front fenders and interfenders thanks
Re: 70 challenger under coat [Re: GardnersGotCudas] #1177426
02/13/12 04:44 AM
02/13/12 04:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There are two basic undercoating schemes for your car. One is the optional full undercoating car, the second was standard undercoating.
Which one did you car come with?
What people call a "non undercoating" car actually did get undercoating. It was just limited to certain areas. Where the full undercoating covered a lot more areas.
Re: 70 challenger under coat [Re: autoxcuda] #1177427
02/13/12 04:54 AM
02/13/12 04:54 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
From what I understand, there was "Undercoating" and there was "Sound Deadener". The standard was to put the pancake batter style Sound Deadener in the wheelhouses/fenderwells. This was to quell noise from kicking up rocks or other small road objects. More often than not, the rear had a thicker application than the front.
