Do I need a vacuum pump #1177319
02/12/12 07:46 PM
02/12/12 07:46 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I'm wondering if I need a vacuum pump with my twin turbo build (street/strip) car looking for 1000rwhp? W9 headed stroker.
Re: Do I need a vacuum pump [Re: W9 Dart] #1177320
02/12/12 09:18 PM
02/12/12 09:18 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
i dont know if my W9 motor will wont a vac pump but its getting one.I believe to get max HP from one you should have the right ring pack
Re: Do I need a vacuum pump [Re: Otherlane] #1177321
02/12/12 09:28 PM
02/12/12 09:28 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
my rings are set up for boost... I have just heard mixed opinions on the subject
Re: Do I need a vacuum pump [Re: W9 Dart] #1177322
02/12/12 09:31 PM
02/12/12 09:31 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I've hurd not to run one on the street
Re: Do I need a vacuum pump [Re: W9 Dart] #1177323
02/12/12 10:54 PM
02/12/12 10:54 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
need one NO,are they awesome to have YES,if u like no leaks whats so ever!and in most cases will help in the hp dept i have one and will always from now on. good luck w ur build it sounds good.
Re: Do I need a vacuum pump [Re: fishy340] #1177324
02/12/12 11:04 PM
02/12/12 11:04 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
my brother has one on his ford and picked up 40 hp
Re: Do I need a vacuum pump [Re: fishy340] #1177325
02/12/12 11:22 PM
02/12/12 11:22 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
Any particular brand and model you think I need for my application?
Re: Do I need a vacuum pump [Re: Otherlane] #1177326
02/12/12 11:24 PM
02/12/12 11:24 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
You don't need one.I have never ran one on my car.But if you run alcohol they make it nice for keeping your oil from getting milky.They do help power sometimes not always and you will have atleast a $1,000 bucks plus alot less room.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Do I need a vacuum pump [Re: W9 Dart] #1177327
02/12/12 11:27 PM
02/12/12 11:27 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
If your going to put one on it put the best on it.There is no better pump than a star vacuum pump.
Re: Do I need a vacuum pump [Re: bdaz smblk] #1177328
02/12/12 11:43 PM
02/12/12 11:43 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
That's what I'm talking about... Some say yes I need one others say no. I'm running e85 and most likely no more than 16lbs of boost.
Re: Do I need a vacuum pump [Re: W9 Dart] #1177329
02/12/12 11:51 PM
02/12/12 11:51 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Your build sounds very cool.What size motor is it going to be.
Re: Do I need a vacuum pump [Re: bdaz smblk] #1177330
02/13/12 12:03 AM
02/13/12 12:03 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
R1 4" stroke 416
dragon slayer crank
carrillo rods
9.5 cr CP pistons
Re: Do I need a vacuum pump [Re: W9 Dart] #1177331
02/13/12 12:12 AM
02/13/12 12:12 AM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
R1 4" stroke 416
dragon slayer crank
carrillo rods
9.5 cr CP pistons
That thing should be a beast.Please keep us updated.Where abouts are you from.Good luck on the build to .Kenny
Re: Do I need a vacuum pump [Re: W9 Dart] #1177332
02/13/12 12:17 AM
02/13/12 12:17 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I'm in VA
