Re: Do I need a vacuum pump
[Re: W9 Dart]
#1177320
02/12/12 09:18 PM
02/12/12 09:18 PM
Posts: 830 east coast
Otherlane
east coast
i dont know if my W9 motor will wont a vac pump but its getting one.I believe to get max HP from one you should have the right ring pack
[Re: Otherlane]
#1177326
02/12/12 11:24 PM
02/12/12 11:24 PM
Posts: 437 south central pa
bdaz smblk
south central pa
You don't need one.I have never ran one on my car.But if you run alcohol they make it nice for keeping your oil from getting milky.They do help power sometimes not always and you will have atleast a $1,000 bucks plus alot less room.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: W9 Dart]
#1177329
02/12/12 11:51 PM
02/12/12 11:51 PM
bdaz smblk
south central pa
Your build sounds very cool.What size motor is it going to be.
[Re: bdaz smblk]
#1177330
02/13/12 12:03 AM
02/13/12 12:03 AM
Posts: 243 United States
W9 Dart
United States
R1 4" stroke 416 dragon slayer crank carrillo rods 9.5 cr CP pistons
