Re: K-Frame is bent on 70 Charger 440- need replacement
[Re: ef8Cuda340]
#1177253
02/12/12 06:38 PM
02/12/12 06:38 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
E body steering box is at a different angle & in theory shouldn't be used.... That said I swapped a 70 Charger K into a 70 Cuda years ago & it worked fine..... Clear as mud...
[Re: 1_WILD_RT]
#1177254
02/12/12 06:40 PM
02/12/12 06:40 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
I would stick with a 67-70 member, but if you are going to use any listed try the 71 or 72 the 73 should have spool mounts on it.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
[Re: hemi_harvester]
#1177255
02/12/12 06:45 PM
02/12/12 06:45 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
67-69 don't work with the later design sway bar... Gotta be 70....
And to be semi correct on an R/T it should have the skid plate.... Which I'd save off the original K member...
#1177258
02/12/12 07:29 PM
02/12/12 07:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
A 73 B body would have spool mounts,....all the E bodies are the same K, 70-4...no spool mounts
[Re: QuickBpBp]
#1177260
02/13/12 01:12 AM
02/13/12 01:12 AM
Posts: 202 Texas
ef8Cuda340
Texas
I have a nice un-bent super clean 70 Charger "coin" K-member. I'd sell it for $75 but shipping would kill the deal....
I am interested, but need your contact information.
[Re: 1_WILD_RT]
#1177265
02/13/12 06:15 AM
02/13/12 06:15 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
my 70 U code had a skid-plate on it as well...I was baffled by it when I first saw it. Was before moparts...almost at the dawn of the Internet. Sure enough...440 Skid plate. I think 68-69 can bolt in bowever the sway bar mounts are in a different place on the 70. my Sway bar went through the K-Member between the skid plate and the member and bolted to the member by 2 bolts and one bracket on each side..on a 69 the sway bar goes over the front extension to the radiator support and bolts to the lower control arm. I don't see why a 69 wouldn't work, just have to open 2 holes on each side for the front sway bar brackets (if you have sway bar)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
