Re: March Meet plans out the window..... [Re: clonestocker] #1177059
02/19/12 09:06 PM
02/19/12 09:06 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
The failure was discussed at length and we're quite certain the rod was hurt when the epoxy let go in the "repaired" #3 intake port of our other set of heads. It wasn't picked up on the teardown, nor would it have been obvious, but it is now! Now we've cracked the head around the guide..... so between four W5 heads we still have two that are "ok"..... actually the one we have out here is going to be repaired, and if the crank can be used again we'll base another build around the 4" crank. If it's not good.... we'll see. Either way I think we'll make a choice one way or another to have some sort of small block up and running by April.
Re: March Meet plans out the window..... [Re: J_BODY] #1177060
02/20/12 12:33 PM
02/20/12 12:33 PM
SD USA
neonic Offline
neonic  Offline
SD USA
Does he not have the 360 still.
Re: March Meet plans out the window..... [Re: neonic] #1177061
02/20/12 08:11 PM
02/20/12 08:11 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Yeah we still have the 360.... But what's the fun in that!
Re: March Meet plans out the window..... [Re: J_BODY] #1177062
02/21/12 02:29 AM
02/21/12 02:29 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
ouch, good luck on the rebuild
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: March Meet plans out the window..... [Re: Stroker Scamp] #1177063
02/22/12 02:03 PM
02/22/12 02:03 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
So Jay.....you going?.....not going?......what's the word?....we fired the old mans pump gas 512. Dug my car out and got it going too.....loading up this weekend.
Re: March Meet plans out the window..... [Re: Chassisman] #1177064
02/22/12 02:08 PM
02/22/12 02:08 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Ron - I need your number.
Re: March Meet plans out the window..... [Re: Chassisman] #1177065
02/22/12 03:53 PM
02/22/12 03:53 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Ron, we will be attending..... just no car. My "80" falls a year short of their "79-older" requirement......although the though has crossed my mind!
Re: March Meet plans out the window..... [Re: J_BODY] #1177066
02/22/12 06:11 PM
02/22/12 06:11 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
...They don't EVER check....There is a certain Dodge truck that runs the Heritage Series that has rectangular headlights and 83 DOT on the tail lights....
Re: March Meet plans out the window..... [Re: Chassisman] #1177067
02/22/12 06:14 PM
02/22/12 06:14 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
And make sure to bring a golf cart......or get a new pair of shoes....if you've never been you'll wear yourself completely out....lol
Re: March Meet plans out the window..... [Re: Chassisman] #1177068
02/22/12 08:12 PM
02/22/12 08:12 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Golf cart is still loaded. We may just haul the Mira....er, 79 Magnum over to run.
Re: March Meet plans out the window..... [Re: J_BODY] #1177069
02/23/12 02:03 PM
02/23/12 02:03 PM
Lil Demon Offline
Lil Demon  Offline
Haul it - Jay - me your number
