welding a coated header #1176992
02/12/12 12:02 PM
02/12/12 12:02 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i was reading on one of the header collector sites that headers can not be welded once they have been coated. is this true? i thought i could just grind off the coating and weld on a new collector.
Re: welding a coated header [Re: mopar dave] #1176993
02/12/12 12:08 PM
02/12/12 12:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just grind the coating off.... its normal metal
under it... I've done it MANY times
Re: welding a coated header [Re: MR_P_BODY] #1176994
02/12/12 12:24 PM
02/12/12 12:24 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks mike
Re: welding a coated header [Re: MR_P_BODY] #1176995
02/12/12 12:26 PM
02/12/12 12:26 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I saw someone use hose clamps on each side of a seam to limit what was ground off then it was tig welded.total of 1/2" was exposed.
home of the
Sox and Martin Hemi Duster
Re: welding a coated header [Re: HEMIFRED] #1176996
02/12/12 02:37 PM
02/12/12 02:37 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
That's a good idea HEMIFRED all you need is it ground off where you must make the weld. But most of the time I grind just a little extra because the heat will burn it off while welding it,there is no problem with that other than the smoke & fumes.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
