Re: 17" wheels on abody
[Re: maxwedge1]
#1176957
02/12/12 11:31 AM
02/12/12 11:31 AM
moparpollack
Lil Herman
Lil Herman
85086
Anything you wil ever need to know about this subject. http://www.forabodiesonly.com/mopar/showthread.php?t=58491Mustang wheels are cheap, get ready to get die grind out the centers.
[Re: moparpollack]
#1176958
02/12/12 11:42 PM
02/12/12 11:42 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
This is another great thread from fabo... http://www.forabodiesonly.com/mopar/showthread.php?t=14254The most classic setup with these wheels is the 245/45/17 tires. There are people who have been able to fit a 275/40/17 on all 4 corners (approximately same height, just wider). Mustang wheels are cheap and easy to do. I would say, try to stay as close to a 0" offset as possible (So around a 4-4.5" backspacing).
[Re: MuuMuu101]
#1176960
02/13/12 04:27 AM
02/13/12 04:27 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
No, try to stay away from 4.0" backspacing. There's a instance right now where someone got 4.0" backspacing and is having rubbing issues in the front of an A-body. Factory backspacing on a 7" rim was 4.25". On a 8" wide rim it was 4.5" backspacing.
You want 4.5 backspacing minimun front. You can go 5.0 easily with stock front spindles. 5.25 is close to the outer tie rod. Between 5.0 and 5.5 will probably be a problem if you run the 2" dropped front spindles.
In the rear, between 4.25" and 4.5" max. If you can't order 4.25" in the rear 4.5" is fine (usually better). But if there is any very slight leaf spring rubbing you can always add thin spacers. If you don't have enough backspacing, your stuck.
[Re: autoxcuda]
#1176961
02/13/12 05:30 AM
02/13/12 05:30 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
That's interesting. For some reason I always had the impression that you always wanted a smaller backspacing up front. I guess you learn something new every day.
[Re: MuuMuu101]
#1176962
02/13/12 12:02 PM
02/13/12 12:02 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
well, A bodies have a narrower rear track than front, so you'd want LESS backspace to widen the rear and fill the wheelwell (look at stock dusters)
pre-05 mustang rims are 5.72" backspacing for an 8" rim (+31mm offset). stock 15x7 mopars are 4.25" backspace (+6.35mm offset) I ran bullits on my M with 3/4" bolt on adapters, for a net backspace of 4.97"...worked great, was able to fit 255/50R17's on all 4 corners. my duster's front wheelwell openings are much smaller, I'm suprised you can fit that big of a tire on them, as my duster gets close with 205/70R14's on the stock 14x5.5" rallyes...lots of positive offset probably helps that.
