Re: Help! Neon tranny line explodes in radiator
[Re: 70Cuda383]
#1176947
02/12/12 12:28 PM
02/12/12 12:28 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Had a few cars at the shop that had that happen.New rad,flush the lines,change fluid and filter.Never had a problem with any of them.If you can find someone with a flush machine thats best for the trans.Might have to change the fluid and filter twice if not.Forgot to add I had one that no coolant got into the trans.Just trans fluid in the rad.Rocky
Chrysler Firepower
[Re: therocks]
#1176948
02/12/12 02:01 PM
02/12/12 02:01 PM
Posts: 3,424 Portland Oregon
69Dartman
Portland Oregon
The clutch packs come unglued when they get wet so maybe if you caught it early enough and got it flushed it will live. All the Neons are known for having lousy tranny coolers built into the radiators that rot through and do what yours did. My 95 developed a crack in the very top though being plastic and high miles so I replaced it with a brand new one for about 100 bucks, still cools fine and no tranny problems. When you do the refill be careful as they tend to superheat as the bubbles work out and blow coolant out the top as it fills and hits the superheated dry spots. I finally just filled the overflow and carefully drove it around and it purged all the air and was fine but before that I had to top it off like 3 times as it kept puking back up when I'd go to check the level in the radiator. They normally run at 199f so they are on the edge of boiling over anyways without a pressure cap in place and at least 50/50 antifreeze.
Life's a little bit better when you hit a Camaro.
[Re: Dakota_Don]
#1176953
02/12/12 11:29 PM
02/12/12 11:29 PM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
Another good idea is to by-pass the radiator cooler and install an aftermarket cooler in front of the radiator. Won't have to worry about it again. Everyone with a Neon should do this as a precautionary measure.
[Re: Kelob_pie]
#1176955
02/13/12 10:30 AM
02/13/12 10:30 AM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
...do you think I caught it in time that the tranny could get away with just a flush (and cooling system of course).
seriously doubt it.
Like mentioned clutch discs do NOT like coolant and it WILL fail.
If you intend to keep the car pull it and be done with it.
