Re: Neon won't start
[Re: catman56]
#1176626
02/12/12 07:02 AM
02/12/12 07:02 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
When you say it "has fuel", do you mean fuel in the tank, or fuel pressure at the injectors? It sounds like you may have an electrical problem that is causing a no-power issue with your fuel pump, or maybe with the entire power distribution center where the pump relay is located. I had the fuel pump go out on my '98 Neon about a year ago, and did all the troubleshooting (from my Haynes manual) first to make sure I really had to drop the tank and replace the pump. You should be able to hear the pump running for a few seconds when you first turn the key to the "on" position. You can hear it from the drivers seat if it's quiet out, or if you have your head down by the rear wheels you can hear it if you have a helper turn the key on. That would be a starting point - if the pump doesn't run for a few seconds when you first turn the key on, the car isn't going to start. If the pump isn't running, check for power at the relay and go from there.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: rallye73]
#1176631
02/12/12 11:47 PM
02/12/12 11:47 PM
Posts: 422 Ozone Park , New York
CudaJames
Was anything done to it before you had this issue ? How much fuel pressure ? Aside from corrosion at the relays , check to see if they are burnt . Check the connectors in the fuse block to make sure they aren't loose . it can lead to high resistance & low voltage to the pump . Another problem could be the hose from the mass air flow to the intake .
70 Challenger Convert , 70 Barracuda 383 Convertible Project (USCarTool.com), 71 Cuda 340 project , 72 340 4spd Barracuda project , 69 Fury III Convertible project ,82 Ramcharger Cummins Conversion project , 1971 Demon - Father/Son project , '19 RedEye
