Re: What brand of slicks is better?
[Re: hugo]
#1176273
02/11/12 12:33 AM
02/11/12 12:33 AM
Posts: 8 North Carolina
Mopar Dragster1
North Carolina
I run Hoosiers on my dragster and really like them. How heavy is your car? Leaving off a brake or not? Why type suspension do you run? All of these are critical to what size and compound you may need.
MOPAR - You are either with us or behind us
[Re: Chris2581]
#1176276
02/11/12 01:19 AM
02/11/12 01:19 AM
Posts: 2,513 PA
moparacer
PA
Until they get some good rubber down nothing is going to work very good.
I used PH338 Phoenix slicks last year and went 1.30_ 60 fts and they hooked all summer in the heat.
I also like the M/T 32X14 3074S. Its a stiff sidewall but it worked great on my car.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: hugo]
#1176277
02/11/12 01:43 AM
02/11/12 01:43 AM
Posts: 469 Tennessee
steeldust
Tennessee
I have to buy new tires for my car. I currently use 32X14.5 goodgyears d-5 compound. THe tires worked good but after about 50 passess my et went from 1.30 to 1.36. THis was at a good prepped track in the summer time. When tires went to 1.36 they were about 3 years old becuase a stopped racing for a year. NOw their opening the track here in Laredo Tx will probraably not be a very good prepped track since they have not used it for quiet a few times. What brand would be better the same ones or should I go to M/T, Hoosier or Phoenix? Wich tires hook better and last longer? On a side note I am not running tubes so I will have to use stiff sidewall and somethig in the 103 roll out. What do you guys recommend?
I run GOODYEARS 33X141/2 they worked the best for my bird but MT & F/X was OK to but now on my DUSTER i was running MT 31x10.5w and they are good but now i went to HOOSIER 32X13 ? But i think your slicks got to old after one year and they set all winter your 60 ft will go away and will go slower because the rubber will dry out GOOD LUCK
[Re: steeldust]
#1176278
02/11/12 09:50 AM
02/11/12 09:50 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
My car is 3300 at the tree. I have never had good luck with the M/T tires. Hoosier for me. I would love to try Pheonix but they dont have a tire with the section I need. Goodyear... the best tire overall but pricey and don't last that long (as I have heard). My SS friends will only run the Pheonix on thier Stocker, Super Stocker, 2 Comp Elim cars and I think even on the 68 Hemi Baracuda.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: StandOnIt]
#1176279
02/11/12 11:11 AM
02/11/12 11:11 AM
Posts: 48 PA
Belvedere500ci
PA
Cant say enough about Hoosier and the 30x9 Radial!
1967 Plymouth Belvedere II 383 1968 Plymouth Barracuda 383 2005 Ram 3500 5.9Diesel 1979 Dodge Power Wagon 360
[Re: hugo]
#1176284
02/11/12 06:10 PM
02/11/12 06:10 PM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
YOur car is very similar to mine in et's mine is going 9.28 at 3700 corrected alt. The fastest I've been is 1.29 when tires were new.Are you running tubes? Why is changing the tires and rims from side to side very important? I guess the rubber on my GY's got old and my et increased...
Yes, I run tubes. In the past when I ran the tires one direction it seemed that the sidewalls would wear out before the tread did. Meaning the 60' and reaction times would lose consistency. Works for me.
[Re: hugo]
#1176287
02/11/12 07:37 PM
02/11/12 07:37 PM
Posts: 2,513 PA
moparacer
PA
Its harder on the sidewalls if you run them without tubes. That is why we rotate them every now and then.
I think a lot of your problem was the age of the slicks.
I could never run a 3 year old set on my car.
