am radio #1176074
02/10/12 05:09 PM
02/10/12 05:09 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
I have a ebody am radio that i want to power up on bench and test. Can anyone tell me which wire to use for power and ground? Has an orange and red combined and a green and black joined
alphadunn@sympatico.ca
Re: am radio [Re: sailboat] #1176075
02/10/12 06:01 PM
02/10/12 06:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Black is usually ground (-) and orange is usually instrument light power (+) so the orange/red is power and green/black is ground.
Re: am radio [Re: sailboat] #1176076
02/10/12 06:03 PM
02/10/12 06:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
orange is face lighting and red is normal battery voltage to power the radio. The green and black wires go to the 2 connections on speaker. Separate ground wire should get attached to radio housing from your 12 volt source.
Re: am radio [Re: buildanother] #1176077
02/10/12 06:21 PM
02/10/12 06:21 PM
canada
sailboat Offline OP
sailboat  Offline OP
canada
Got the wire arrangement, makes sense. Thanks. Does the radio ground through the small mounting bracket that holds up the rear of the radio? There doesnt seem to be anywhere else for a seperate ground wire to connect. looks like face power, radio power and neg/positive for speakers only. Four total.
Re: am radio [Re: sailboat] #1176078
02/10/12 06:41 PM
02/10/12 06:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The two mounting bolts that go up into the front of the radio have teeth on the captive washers. Those teeth sould cut into the dash frame and provide a ground.
Re: am radio [Re: sailboat] #1176079
02/10/12 07:43 PM
02/10/12 07:43 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Radio is also grounded through the outer shield of the antenna wire..
Just my $0.02...
