360-2's on a 48 degree block #1175899
02/10/12 11:57 AM
02/10/12 11:57 AM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
Anyone got photos of a 59 degree Indy 360-2 head on a 48 degree block with valve train in place. Just wanted to see where the pushrods sit. Will the heads need much grinding on the intake face of the manifold and heads.
Re: 360-2's on a 48 degree block [Re: tuff440] #1175900
02/10/12 12:03 PM
02/10/12 12:03 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I don't have 360-2's, but I do have 59 degree W2 econo's on my engine. It works, its tight, but it works. Had to clearance for push rods.
-Kenny
Re: 360-2's on a 48 degree block [Re: StrokerAspen] #1175901
02/10/12 12:10 PM
02/10/12 12:10 PM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
Exactly what I wanted to see. Thankyou
Re: 360-2's on a 48 degree block [Re: tuff440] #1175902
02/11/12 03:40 AM
02/11/12 03:40 AM
Alberta Canada
Alberta Canada
No problem! Glad I could help. I would say my W2's would be worst case too. The heads are decked .100".
-Kenny
Re: 360-2's on a 48 degree block [Re: StrokerAspen] #1175903
02/11/12 05:44 AM
02/11/12 05:44 AM
Sydney, Australia
tuff440 Offline OP
tuff440  Offline OP
Sydney, Australia
Kenny, the reason I ask is because I didn't like the geometry on a 59 degree block, which is what I have. I know Ryan J has changed a 59 setup to 48 by fitting iron slugs to the original lifter bores and then re-drilling in the new location and adding sleeved lifter bores.I already have the siamese 59 block and rotating assembly which is balanced, but I don't think mopar does a 48 degree R3 block with supplied bores of 3.90. My pistons are 3.96. Can the ritter blocks be supplied with a rough bore of 3.90?
Re: 360-2's on a 48 degree block [Re: tuff440] #1175904
02/11/12 11:15 AM
02/11/12 11:15 AM
Alberta Canada
Alberta Canada
Good question. I forget what my block came at, but we just had another 48 degree R3 come in the door. I will look into it for ya. I would think Kent could sell you a block with the small bore if you wanted to go that route with a Ritter block.
-Kenny
Re: 360-2's on a 48 degree block [Re: StrokerAspen] #1175905
02/19/12 03:12 AM
02/19/12 03:12 AM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
-Kenny
Whats the word on the R3 block that came through ur door? I have a built R1 59* block with custom pistons for boost... but i'm running ported W9 heads and the push rod angle scares me a little because of the lifter bore spacing...Trying to figure out my options.. I have a .650 offest rocker but can only run a 5/16 push rod and again I'm not a fan of that angle.
What r u thoughts?
Re: 360-2's on a 48 degree block [Re: W9 Dart] #1175906
02/19/12 12:25 PM
02/19/12 12:25 PM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
Re: 360-2's on a 48 degree block [Re: StrokerAspen] #1175907
02/19/12 06:59 PM
02/19/12 06:59 PM
Melbourne, Australia
hmi360 Offline
hmi360  Offline
Hi Kenny, just wondering what sort of roller lifters are those? with the tie bars on the top like that?
Cheers
Re: 360-2's on a 48 degree block [Re: hmi360] #1175908
02/19/12 07:07 PM
02/19/12 07:07 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Cheers
installed backwards that's what kind
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
