carb size #1175740
02/09/12 10:48 PM
02/09/12 10:48 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok guy's what size carb do i need 440 std bore 2295's 12.1 comp. comp cam 564 lift hyd. team g intake 4500 series port work on stealth heads valve job ?
Re: carb size [Re: buck440] #1175741
02/10/12 12:06 AM
02/10/12 12:06 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
4500 series? 1050.
Re: carb size [Re: buck440] #1175742
02/10/12 03:25 PM
02/10/12 03:25 PM
I have used a early Holley 9375 non HP with stock jetting very successfully on a similar motor except for the cam,it had the Mopar 590 solid cam. That motor made 562 HP with a not so good set of iron 346 heads Yours should make a little more HP and torque due to the better heads Probally 30 to 50 more each due to the CFM differences flow between the heads
Re: carb size [Re: Cab_Burge] #1175743
02/11/12 04:46 PM
02/11/12 04:46 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
hell yeah thats what im talkin bout...
