Journey RT need opinion from dealer tech #1175638
02/09/12 10:14 PM
02/09/12 10:14 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
Today the drivers door controls screwed up,the windows wont roll down in the front on the drivers door buttons but the rear windows go down with drivers button,power mirror switch not working either check fuse for that stuff it was ok....any ideas on if its the whole switch is bad or what else could cause it.
Thanks for any info i want to fix this myself if possible
....lock/unlock button not working either
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Journey RT need opinion from dealer tech [Re: 451 D*O*D*G*E] #1175639
02/09/12 11:17 PM
02/09/12 11:17 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I would bet on the wiring harness between the door and the body is broken. There was a recall for this on some models. K07 I believe was the number. Could also be the drivers door module if the car is equipped with express windows. The rear windows will still operate if the module is bad.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Journey RT need opinion from dealer tech [Re: 71yelladustr] #1175640
02/09/12 11:47 PM
02/09/12 11:47 PM
Hr up from KCK
Hr up from KCK
Thanks for the help what is the module?Is it part of the switch?I am not up on newer vechicles thanks alot for the input
What are express windows?
Re: Journey RT need opinion from dealer tech [Re: 451 D*O*D*G*E] #1175641
02/10/12 12:01 AM
02/10/12 12:01 AM
Missouri U.S.A.
Missouri U.S.A.
The module is located in the door and is used to cut down on the amount of wiring need in the door to perform all of the functions associated with the door, like the power windows and mirrors, etc... It is separate from the switch and the door panel must be removed for access. Express windows are the one-touch down and/or up with the switch. switch should say AUTO if equipped.
10.02@134
Re: Journey RT need opinion from dealer tech [Re: 451 D*O*D*G*E] #1175642
02/10/12 12:06 AM
02/10/12 12:06 AM
Hr up from KCK
Hr up from KCK
Searched the net a bit wow theres like 6 recalls we bought the car last september havnt gotten a single recall letter how do you find out if a previous owner had these recalls peformed?
Wiring harness rub on axle 3.5
faulty pcm circuit board
The breakage in door you refered to
extra hot wire on aux 110v source could catch fire.
Sounds like the door prob could even cause the air bag not to deploy.
hhmmmm..
Re: Journey RT need opinion from dealer tech [Re: 451 D*O*D*G*E] #1175643
02/10/12 12:07 AM
02/10/12 12:07 AM
Hr up from KCK
Hr up from KCK
Yeah we got the express windows,thanks
