valve train help #1175632
02/09/12 09:59 PM
02/09/12 09:59 PM
Fredericton NB Canada
471b1dart Offline OP
working on a 77 dodge 4x4 with 30,000 miles on it , customer had some one install a edelbrock performer cam and lifters , and new pushrods ,an Intake and 4bbl now the engine has a tapping noise coming from vavetrain area that is intermitant, took vavle covers off everything looks fine, If it were mine I would have replaced rockers too. some times the noise seems to come from bellhousing area too, any suggestions what to look for would be appreciated
Re: valve train help [Re: 471b1dart] #1175633
02/09/12 10:08 PM
02/09/12 10:08 PM
1st see what you have for preload
Re: valve train help [Re: RapidRobert] #1175634
02/09/12 10:11 PM
02/09/12 10:11 PM
ok , but it has non adjustable rockerarms , how to check for preload??
Re: valve train help [Re: 471b1dart] #1175635
02/09/12 10:27 PM
02/09/12 10:27 PM
On #1 cyl on base circle (TDC #1 cyl compression) measure how far the rocker arm assy compresses the lifter cup down starting from all the way up against the retainer. Use a sharpie on a pushrod before/after in relation to a reference mark to a straight edge across the head valve cover flat rail. (iirc .020-.030" is enough) one or more may be borderline too close since it's intermittent tho I did have a late hyd lifter /6 w noise that came & went & never had a prob ex for the occaisional noise but it was bothersome & it was not hotrodded so I put up w it
Re: valve train help [Re: RapidRobert] #1175636
02/09/12 10:59 PM
02/09/12 10:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Did the exhaust valves have rotators. If so get rid of the m and get some regular springs and retainers. Rotators and springs are very short and good source for coil bind with much over a stock cam
Re: valve train help [Re: MoparforLife] #1175637
02/10/12 08:16 AM
02/10/12 08:16 AM
thanks for the help , gives me some things to look at a little closer
