Street machine launch chassis tuning help
#1175489
02/09/12 03:53 PM
02/09/12 03:53 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I have a '72 demon I'm setting up for cruising and stoplight fun. The car sits flat at rest but after a few launches the driver's side stays higher than the passenger side. The twist doesn't seem dramatic since I welded in frame connectors, but it's gotta be lifting the drivers side higher and the 90/10 shocks aren't letting it settle. This is with my 300lb fat butt in the driver's seat too!
I want some strategies to launch straighter and settle flat better. I don't want to spend a bunch of money, I want to tune what I already got. I am not looking to 1.20 60foot with a mild motor and street tires, just want to have fun and learn more about chassis tuning.
Currently: mild 408 LA 350hp/400tq at the tires 3.09 1st gear 4.11 8.75 rear 275/60-15 bfgs (traction limited I know) 002/003 leafs w kybs and shock extensions, corrected shackle angle /6 T-bars 90/10 comp front shox (set to 90/10) Stock front sway bar Stock torque boxes 2"x3" .125 wall frame connectors welded in
Issues/Ideas/Options I'm already considering: -My 002/003 springs don't sit higher on one side. I understand they're supposed to do that and if they did maybe it would help?
-I have comp 3ways for the rear, never tried them
-thinking about setting front left shock to 70/30, leaving rt at 90/10
-small stock front sway bar should hurt the launch, but help with flatness/ evenness, right? I leave it hooked up in the street
-Thinking about messing with t-bar preload- ideas?
Sorry for writing Moby Dick here- thanks in advance to anybody willing to help out with any tips or ideas.
radar
Re: Street machine launch chassis tuning help
[Re: radar]
#1175490
02/09/12 04:05 PM
02/09/12 04:05 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Dude, 1.20 ET 60 fts on BFG 275x60x15 on the street, get real Especiially using a 4 speed Maybe 1.55 60 ft.on a good day BTW, the 002-003 should show preload on the passenger side, thier designed that way, even with your fat butt( ) in the car
[Re: radar]
#1175491
02/09/12 06:24 PM
02/09/12 06:24 PM
radar
Philadelphia
Geez! Skim much?!
[Re: radar]
#1175492
02/10/12 01:35 PM
02/10/12 01:35 PM
Posts: 642 New Jersey
Craig
New Jersey
If those tires are not drag radials, I'd say you aren't going to be able to load the rear suspension enough to gain much there in rear shocks or adjustments. The front lift would be an issue though. I wouldn't set the front shocks different from each other. I would suggest a shock soft in both directions like the Koni SPA-1. I don't think removing the swaybar would do much, while worsening the driveability. There may be benefit in adjusting your torsion bars, a 4-corner scale would be nice but you could just adjust and test.
On the other hand, do the leaf springs still show arch at the backs? There were a lot of bad SS springs made that went soft, I had some that lost their arch in 2 years and threw them away. Bad leafs may be part of the problem even with hard tires.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: radar]
#1175493
02/10/12 01:45 PM
02/10/12 01:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The sway bar isnt helping your launch and settling but your a street car so you may want to keep it... your never going to get a 1.20 with your set up
[Re: Craig]
#1175494
02/10/12 02:02 PM
02/10/12 02:02 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Get some loose front shocks and bias ply ET Street or QTP tires for the rear. A bias ply tire is your friend if you want traction on the street, not a drag radial. Unhooking the sway bar will free up the front end, but at the cost of some driveability...not much though in my opinion.
SS springs should sit higher on the passenger's side. If they don't then I'd tend to think you got some bad springs.
[Re: radar]
#1175495
02/10/12 02:04 PM
02/10/12 02:04 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Carry on!
[Re: RobX4406]
#1175496
02/10/12 06:56 PM
02/10/12 06:56 PM
Posts: 520 New Zealand
nz383man
New Zealand
Check out this youtube clip http://www.youtube.com/watch?v=ZNGnu4uPB1s&context=C3c532ebADOEgsToPDskLWMGYk7LxUwuowko-nXgOvMy mates Challenger has a stroked bigblock that has done 12.5 sec on a bad track, he has high gears (2.7?) but it has so much torque it would still 60' fine if he could get traction, he has firm shocks, sway bars & 295? Cobra street radials. My Barracuda has a low comp 383 that has only ever run 14.2 at best (iron intake & exhaust, factory AVS carb etc) I run HP (440-Hemi) rear springs with clamps, adjustable pinion snubber, Summit drag shocks (set on medium) , 3.91 suregrip & 275-15 x 50 Quicktimes, small block T bars, Summit drag shocks set at 90-10, no sway bars front or rear. Both cars are autos & stall about 3K. We were racing on a chip seal runway whick is much the same as our roads in New Zealand (poor traction) Like yourself I wanted to learn how to get the power I had to the ground before I made it worse by adding power. Now I'm building a stroked & tunnel rammed dual plug Hemi for the Barracuda so I geuss I'm in for a few more traction issues.
[Re: Mr.Yuck]
#1175498
02/10/12 11:23 PM
02/10/12 11:23 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
set up the drivers side t-bar ride height with your weight in the drivers seat.. i might even suggest and alignement done the same. disconnect the front sway bar for dragracing your rear shock set up ( i hate shock extenders).. but if you can adjust rear shock settings...give it a looser rebound setting than the compression setting..
next is dialing in the pump shot on the carb.. best of luck...
slicks will make a big difference....
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: gregsdart]
#1175500
02/11/12 12:54 PM
02/11/12 12:54 PM
radar
Philadelphia
I have a set of phoenix 10.5"x28" slicks, they definitely can take a harder hit than the bfg street tires! Traction is not my question, I want strategies for tuning the launch to lift the front end more evenly and settle flatter. Are a full cage and $500 shocks my only options for a flatter launch?!
I went and measured, the leafs are definitely arched and the passenger side is 3/4" higher. Not that noticable. They feel just as stiff as when I got 'em. The alignment is recent. I feel like if my weight was the problem the drivers side would stay lower, not higher? Are the comp 90/10 shocks that much stiffer in extension than spendier ones?
Maybe I asked my question wrong? I used to have 1.08 bars, now with the .83 bars and cheap 3way drag shocks I am getting MUCH more weight transfer. I am pretty good at getting just a little chirp and a little front end reaction even with street tires. With the limited traction and 3.09 1st the fun is in seeing how hard I can hit it without spinning. Maybe there's nothing wrong and I'm just buggin. Lots of kinda fast cars with slicks and a well prepped track only barely lift the drivers tire right? (an example of common chassis twist in mild drag cars, I DO NOT expect to see daylight under any of my tires in the street)
Thanks for any responses, Im not trying to be ungrateful, just please understand I want to learn about tuning for straightness in general not making an ideal setup for the track!
[Re: radar]
#1175502
02/11/12 10:32 PM
02/11/12 10:32 PM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Soft torsion bars are going to ride high under load. Another thing is that the harder the car hooks, the more the reaction changes and the more moves the suspension will make. So it is all relative to how hard the tires bite.
