Anyone know K-cars? 2.2 Q's.
#117535
09/08/08 09:40 PM
09/08/08 09:40 PM
Posts: 9,887 USA
CrAlt
USA
Hey all. Im working on a little 89 Reliant K. It has a TBI 2.2.
It idles all over the place sometimes and is real weak off the line. (i know its only a 2.2.. but my 88 aries was much stronger off the line). I went to check the timing and with the coolent temp sens plugged in it jumps all over the place. With it unplugged it jumps up and down a deg or 2.
Also, the timing belt has a mark on it from the grove in the tensioner pulley. There are no cracks and it doesnt look like it jumped timing. What is the life expectancy on these belts?
Thanks.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Anyone know K-cars? 2.2 Q's.
[Re: CrAlt]
#117536
09/08/08 10:05 PM
09/08/08 10:05 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
Well, It's been a while since I had my LeBaron GTS Turbo 2.2 L, but I'll try.
You are doing the right thing by disconnecting the coolant sensor whilst checking the timing.
The "Hall Effect Sensors" in the distributors fail quite often , and they are cheap and easy to replace. First, check that connector, though !
The timing belts are rubber (of course) and the maintenance interval is around 60K miles. My car was still running fine at 173K with one timing belt change. I had gone through 3 head gaskets by then, though ( it WAS a Turbo).
Good luck.
[Re: CrAlt]
#117538
09/08/08 10:18 PM
09/08/08 10:18 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
These cars will run REAL bad if they starve for fuel. If the fuel filter is old, put a new one on.
I personally was in an 88 dakota when the belt threw on its 2.2...we dragged it back to the house and threw a new belt on...good to go. I wouldn't be too worried.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#117539
09/08/08 10:33 PM
09/08/08 10:33 PM
Posts: 9,887 USA
CrAlt
USA
OK ill pull and clean the idle motor. I'll also change the fuel filter.
I still dont know if the jumping timming is making the idle erratic or if the erratic idle is making the timing jump around.
Here's the timing belt. Ive been looking at the FSM and it doesnt look like a big deal to change. I'll just do it so i dont get stuck 500 miles from home.
[Re: CrAlt]
#117540
09/08/08 11:07 PM
09/08/08 11:07 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Hows the compression? Did you do a recent compression test? 2.2 engines tend to carbon up the intake valves to the point of plugging up the bowl. It usually happenned in the center two cylinders. That could explain the down on power feeling. Usually the head gasket goes next. Combustion chamber treatments every 10,000 miles or so is recommended to keep this from happenning. I have removed a few heads and physically removed the carbon buildup, polished up the valves/bowls etc. That tends to restore the power.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#117541
09/08/08 11:28 PM
09/08/08 11:28 PM
Posts: 9,887 USA
CrAlt
USA
Would a differance in compression from cyl to cyl be a sign on a gummed up intake valve?
I took apart a TBI 360 once and the intakes where so gunked up i dont know how it ran...
[Re: CrAlt]
#117542
09/08/08 11:59 PM
09/08/08 11:59 PM
racealittle
If the air can't get into the cylinder to get compressed...? I would think that if a cylinder or two are not funtioning properly on a 4 cylinder (loss of efficiency), that might explain why it is down on power. That was my experience. I didn't ask for it to be my experience. The service manual mentions frequency of combustion chamber treatments to be important. We just have extremely poor quality gas in Canada. There must be some sort of reversion problem with the center cylinders that the engineers knew about and chose not to fix until they got away from throttle body injection.
[Re: racealittle]
#117543
09/10/08 04:29 PM
09/10/08 04:29 PM
Posts: 9,887 USA
CrAlt
USA
Well the compression checks out. It seems to be running rich at times. I changed the O2 sensor with no change. If i rev it in N it spits some black smoke. And the cat seems to get real hot real quick I noticed the hose to the EGR is plugged. Could this effect idle if its closed all the time?
[Re: DaytonaTurbo]
#117545
09/10/08 07:46 PM
09/10/08 07:46 PM
Posts: 9,887 USA
CrAlt
USA
K. Good advice. Ill have to rent a gauge for EFI. Tonight im working on replacing the timing belt.
[Re: CrAlt]
#117546
09/10/08 09:31 PM
09/10/08 09:31 PM
Posts: 9,887 USA
CrAlt
USA
Well since i dont have the special mopar tool PN 45534354.34455,3 to adjust the belt tension im am just guessing here... http://www.youtube.com/watch?v=xh4KDJFBxUMhttp://www.youtube.com/watch?v=l5OsoMgRJFMIt flaps up and down i'ed say 1/2" maybe. It sounds like i dont want this thing to be tight like a Vbelt but i hope its not to loose And for some reason with the engine half apart it started to idle normal.
