Neutral safety switch--------------Where to find one??? #1175179
02/09/12 01:58 AM
02/09/12 01:58 AM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Hi. Am finding out how much fun it's NOT to locate a single prong neutral safety switch for 65-68 727 torqueflite. Fleabay has them for 47 bucks with 11 bucks for shipping. Anyone know where to find one a little bit cheaper? I've checked the usual places like YO, Mancini Racing, Dixie Restoration, Dante's Mopar, Herbs parts. Everybody seems to have an abundance of the three prong NSS. Thanks, Joe
Re: Neutral safety switch--------------Where to find one??? [Re: moparjo68] #1175180
02/09/12 03:29 PM
02/09/12 03:29 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Neutral safety switch--------------Where to find one??? [Re: closer9] #1175181
02/09/12 03:35 PM
02/09/12 03:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Have you checked with the local parts houses? Some things are around. you just gotta know how to look em up, as they won't be in the computer, have the counter person look into some actual books. Also Rock Auto is a good resource for older stuff. might wanna call a couple transmission shops local and see what they have to say.
I wouldn't think you should have too much trouble finding them at a decent price. The places you mention are, for the most part "Race" orientated.
OK just checked Rock auto and they show the 3 prong for 68 (?) and nothing for older cars. It is only $9.oo and change. I guess the one prong is not so available as I would have thought. I think you can use the 3 prong and just use the correct prong. I don't know wich one but others will.
I have mechanical Aptitude.
I can screw up anything.
Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175182
02/09/12 05:10 PM
02/09/12 05:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You cannot replace a single prong NSS with a three prong. look in the tech archives for correct info.
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175183
02/09/12 08:01 PM
02/09/12 08:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanks stumpy. I knew folks more informed than myself would chime in. Just seemed that the one wire for the neutral safty switch was all that needed to be attached. Might I ask why it will not work? Rooster comb? And where can the O.P. and anyone else, get a new one? I have several old ones but as I use those trannies I might find I need one or two myself. Worse comes to worse I will just bypass it, but my luck I would forget and start it in gear or something dumb like that.
Re: Neutral safety switch--------------Where to find one??? *DELETED* [Re: bboogieart] #1175184
02/09/12 08:04 PM
02/09/12 08:04 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Post deleted by not_a_charger
Re: Neutral safety switch--------------Where to find one??? [Re: Joesixpack] #1175185
02/09/12 08:11 PM
02/09/12 08:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Complete explination as to what is what with NSS in the tech archives with pictures.
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175186
02/09/12 08:20 PM
02/09/12 08:20 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Wow that's pricey, thanks Joesixpack.
Stumpy, I will be going through the archives. I usually have a hard time finding stuff there, but guess now is a good a time as any to learn navigation.
Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175187
02/09/12 08:25 PM
02/09/12 08:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The 2 outter pins are for the back up lights and the center pin is for the safety switch.
HMMM doesn't say it can't be used. Just wich is wich. See I still don't get it. Why can't a person just use the center prong?
Re: Neutral safety switch--------------Where to find one??? [Re: moparjo68] #1175188
02/09/12 08:57 PM
02/09/12 08:57 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
is yours bad? or just needing one?
Re: Neutral safety switch--------------Where to find one??? [Re: mcmopars] #1175189
02/09/12 11:02 PM
02/09/12 11:02 PM
Yes its bad and its leaking as well. Last time I bought one of these, I just went to the auto parts store and they had one behind the counter.................I guess that was 20 years ago. My, how times have changed. I can get the three prong from everywhere and cheap. The one prongs, I can only find on ebay for around 45 bucks. I will hit the transmission shops and see if they have any shelved. If so, I will buy a couple.
I guess if worse comes to worse, I can buy the wiring harness for the three prong, put in a three prong and cut off the two outside wires as I won't be using them. Joe
Re: Neutral safety switch--------------Where to find one??? [Re: moparjo68] #1175190
02/10/12 12:30 AM
02/10/12 12:30 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at the rooster combs and the switchs that go together and it will be plain to see why they won't interchange. It has to do with the area that hits the switch button amd the legth of the switch as well as how they ground.
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175191
02/10/12 12:33 AM
02/10/12 12:33 AM
I'm confused..............what are you referring to as the rooster comb????
Re: Neutral safety switch--------------Where to find one??? [Re: moparjo68] #1175192
02/10/12 12:37 AM
02/10/12 12:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look at the picture of the three levers (rooster combs) and the switchs below each one. You can see that there are two legs that work the first switch ,a notch and a leg for the second switch and a ramp for the third three prong style. You can see that they will not work if switched around. The switchs screw into the trans at different depths also. They won't work unless they are matched sets lever and switch.
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175193
02/10/12 12:49 AM
02/10/12 12:49 AM
So I just can't substitute the one prong for the three pin NSS and add the neutral switch connector plug in and not utilize the two outer wires??? But if this tranny was being placed into a 69 or 70 Mopar, wouldn't the three pin NSS be used instead of the one prong?? This is what's confusing me???
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175194
02/10/12 03:24 AM
02/10/12 03:24 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I did a search of the tech archives and the only thread it would bring up for "neutral safety switch" was this one.
https://board.moparts.org/ubbthreads/show...rue#Post6589590
It doesn't give any info about the single pole style switches, just info on how the 3 pole switch works.
Re: Neutral safety switch--------------Where to find one??? [Re: SNK-EYZ] #1175195
02/10/12 08:26 AM
02/10/12 08:26 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree the comb in the trans has to be changed to use a 3 prong.Its what shifts the trans gears and 3 prongs are different.The 3 will thread in but wont work as the comb wont contact it.Bite the bullet and buy the right switch.Rocky
Chrysler Firepower
Re: Neutral safety switch--------------Where to find one??? [Re: therocks] #1175196
02/10/12 08:40 AM
02/10/12 08:40 AM
AZ
Mike P Offline
Mike P  Offline
AZ
After my last experience with NSSs I just pull an OE one from a junk yard transmission.
When I was building my 76 Dodge truck I needed to have all the lights working to get it thru the level 3 inspection at DMV. It had a bad NSS/backup light switch so I went into town and picked up a Bosch switch from the local parts store. The made in China POS lasted one time thru the gears and died. I was a little Poed to say the least and pulled the switch from a used transmission I had laying around and got the truck thru inspection. When I rebuilt the truck I bought a TCI transmission which came with a new switch installed.....this one was made in India. I’ll admit it was a little better switch....it lasted a week. The 35 year old switch from the used transmission is has been in the truck for 5 years now and is still going.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: Neutral safety switch--------------Where to find one??? [Re: stumpy] #1175197
02/10/12 11:31 AM
02/10/12 11:31 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The rooster comb is simply the name for the trigger for the switch.
You contardict yourself with this last statement. You said it can't be done, and then explain how they can. Hmmm.
Here is the picture that is in the tech archive article.
Although they look different. it appears as though any could be used. The last comb seems to have a high spot where the middle one has a valley, that high spot would be for the back-up lights. After the neutral both combs ramp down to release the switch. For the sake of not having to do it twice I might just replce the rooster comb as well. Here is the picture that is in the tech archive article.
The first one was for pusg button trans the second one is the 66 thru 68 switch and the last one is the 69 & later switch
Re: Neutral safety switch--------------Where to find one??? [Re: bboogieart] #1175198
02/10/12 11:56 AM
02/10/12 11:56 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
early switch, Arrow points to the contact area. The high points on the comb contact in park and neutral to ground the switch and allow the car to start.
