Re: Bent / broken push rods
[Re: JohnRR]
#1175168
02/09/12 09:41 PM
02/09/12 09:41 PM
Posts: 340 Alaska
73rrak
Alaska
No the heads are still on and they are staying on. The extra spring was the problem for some reason Hughes shipped them with the extra spring and Hughes says it's not supposed to be there. The machine shop just installed them the way they received them. Yes they should have checked them but right now I'm just happy to have the problem solved without having to take this thing back apart. Now I just need to get the camera out of the cylinder and maybe I can drive this piece of crap.
now that you have said that you will be pulling that head to get the camera out ...
good luck ...
If it went in through the plug hole why wouldn't it come out the same way?
The issue will be grabbing it to get it make out thru the plug hole, I'm guessing it wasn't much smaller than the plug hole.
If it were me I'd almost be tempted to pull off the intake , pull the intkae valve spring , make sure the exhaust is closed , put the plug back in , lower the piston some and open the intake valve to the point that the retainer with locks is sitting on top of the guide and use a shop vac to try to suck it out the intake port ...
I like this idea I'm gonna try it ....... Thanks
[Re: 73rrak]
#1175169
02/09/12 10:03 PM
02/09/12 10:03 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
good luck ...
Actually after reading your other post it sounds like it's on the plug hole ... I assumed it fell completely into the cylinder ... put the vacuum on the plug hole first , release the valve train so the valves are closed.
When you get it back together , with the valve train off do a leak down test on all the cylinders , this will tell you if you have bent valves .
[Re: 73rrak]
#1175171
02/09/12 10:28 PM
02/09/12 10:28 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't mean to be a jack a$$ but I think I would have had that head off by now.
I have mechanical Aptitude. I can screw up anything.
[Re: 471Magnum]
#1175174
02/10/12 11:55 AM
02/10/12 11:55 AM
Posts: 394 md
wicked
md
Any time I have seen coil bind like that , it has done some very ugly things to the bottoms of the lifters. I'd want to pull the lifters and look at them and the lobes very carefully. Pushrod measurements should be the same unless you have a lobe wiping out.
