Bent / broken push rods #1175147
02/09/12 01:49 AM
02/09/12 01:49 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I'm working on a new 440 that bent the intake push rods just after break in and I'm trying to figure out why. I made a push rod length checker and these are the numbers I came up with :
Stock push rod = 9.292
Rod checker results from lifter cup to rocker cup :
intake = 9.203
exhaust = 9.210
Is this enough to cause all of my intake push rods to bend / break? were should I look now ? I checked the pistons with a bore scope through the spark plug hole and I don't have any damage on my pistons at all so the valves never touched them.
Re: Bent / broken push rods [Re: 73rrak] #1175148
02/09/12 05:04 AM
02/09/12 05:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
if thats the case,,, how/what bent them??? Wht did you use/get unequal lenght PRs? HEMIs are the only Mopar engine that I know of that has unequal length PRs..
I am truckless..
Re: Bent / broken push rods [Re: 340SHORTY] #1175149
02/09/12 08:50 AM
02/09/12 08:50 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I re used the push rods that were in the motor. The motor was out of a 77 motor home with 48,000 miles on it and from the looks of it it had never been opened before I opened it. Although I never heard the motor run before I took it apart it was super clean inside and in completely stock form. I don't know if the push rods were all the same size and now it will be impossible to tell being that all of the intake rods are bent. I didn't mark them or separate them when I took them of the motor so the chances of getting all long ones on the intake only are pretty slim. There has got to be something else wrong in this motor.
Re: Bent / broken push rods [Re: 73rrak] #1175150
02/09/12 10:42 AM
02/09/12 10:42 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Coil Bind
Re: Bent / broken push rods [Re: drew72] #1175151
02/09/12 01:57 PM
02/09/12 01:57 PM
dogdays Offline
dogdays  Offline
MODS!!!!!
This guy has two open threads on this same topic in this forum and one in the race forum.
I'm getting tired of opening a thread and reading the same old whining and guesswork answers.
To the OP:
Take the doggone heads off, but before you do, check valve to piston clearance using a light spring and degree wheel. Get V/P measurement at every 5 degrees from 20 degrees BTDC to 20 ATDC. While you've got the spring off measure its compressed height. Also check the valve stem seal to retainer clearance. Measure the actual pushrod diameter between an end and the bend.
If they all check out it's valve guides.
Between now and the time you get that done don't start another thread about the same thing.
R.
Re: Bent / broken push rods [Re: dogdays] #1175152
02/09/12 02:57 PM
02/09/12 02:57 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
MODS!!!!!
To the OP:
R.
Never mind...
Re: Bent / broken push rods [Re: dogdays] #1175153
02/09/12 03:39 PM
02/09/12 03:39 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Dogdays.... I don't have a post in the race section I've never even been to the race section. I don't have 3 threads going on this same subject. One is for a carb issue that thread lead into the all of my intake push rods are bent one. The 3rd one I have going is me trying to find out what the stock rocker ratio is so I can eliminate that as a possible cause of the problem. I didn't mean to upset anybody I was just trying to solve a problem and have people read 2 pages of posts to get to a question on another part of the problem although it was in the same category.
Drew. and whoever else guessed coil bind I think you might have it. I have a spring off and the valve seal looks fine but I can see area where the spring hammered into the spring perch. I'm working with the machine shop that did the head work I will let you know how that goes.
Re: Bent / broken push rods [Re: 73rrak] #1175154
02/09/12 04:36 PM
02/09/12 04:36 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If it is coil bind and the shop knew the cam specs then let them fix it(if they know how) and never go back. NEVER.
Re: Bent / broken push rods [Re: 73rrak] #1175155
02/09/12 04:39 PM
02/09/12 04:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Was the gas it ran on new? Old gas will leave tar in the intake tract and when the engine cools it cements the intake valves in place. When you crank the engine again the pushrods bend.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Bent / broken push rods [Re: GomangoCuda] #1175156
02/09/12 05:08 PM
02/09/12 05:08 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
It looks like it was coil bind I only have .375 travel on the valve. I found an extra spring that was installed that the machine shop says is not supposed to be there. I have the outside spring the damper and a spring inside the damper. I'm taking the extra spring out and checking it again. I will let you guys know what I find.
Re: Bent / broken push rods [Re: 73rrak] #1175157
02/09/12 05:14 PM
02/09/12 05:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How do they know it's not supposed to be there , the Hughes spring may be a double spring and if it is the spring seat on a factory head is not cut to accept that type of spring arrangement ....
Are the heads off yet ?
Re: Bent / broken push rods [Re: JohnRR] #1175158
02/09/12 05:40 PM
02/09/12 05:40 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Pull the heads and check things correctly. Even in the driveway with hand tools it's only a two hour job.
Re: Bent / broken push rods [Re: JohnRR] #1175159
02/09/12 05:41 PM
02/09/12 05:41 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
No the heads are still on and they are staying on. The extra spring was the problem for some reason Hughes shipped them with the extra spring and Hughes says it's not supposed to be there. The machine shop just installed them the way they received them. Yes they should have checked them but right now I'm just happy to have the problem solved without having to take this thing back apart. Now I just need to get the camera out of the cylinder and maybe I can drive this piece of crap.
Re: Bent / broken push rods [Re: 73rrak] #1175160
02/09/12 05:44 PM
02/09/12 05:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
now that you have said that you will be pulling that head to get the camera out ...
good luck ...
Re: Bent / broken push rods [Re: JohnRR] #1175161
02/09/12 06:01 PM
02/09/12 06:01 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I gave up worrying about saying bad things about this car months ago. It can't get back at me any more than it already has...... hhahahahha
Thank you everybody for all of the help
Re: Bent / broken push rods [Re: JohnRR] #1175162
02/09/12 06:10 PM
02/09/12 06:10 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
good luck ...
If it went in through the plug hole why wouldn't it come out the same way?
Re: Bent / broken push rods [Re: 64Post] #1175163
02/09/12 07:14 PM
02/09/12 07:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good luck ...
The issue will be grabbing it to get it out thru the plug hole, I'm guessing it wasn't much smaller than the plug hole.
If it were me I'd almost be tempted to pull off the intake , pull the intkae valve spring , make sure the exhaust is closed , put the plug back in , lower the piston some and open the intake valve to the point that the retainer with locks is sitting on top of the guide and use a shop vac to try to suck it out the intake port ...
Re: Bent / broken push rods [Re: JohnRR] #1175164
02/09/12 07:36 PM
02/09/12 07:36 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Re: Bent / broken push rods [Re: Twostick] #1175165
02/09/12 08:48 PM
02/09/12 08:48 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
So what did all of this do to the new cam?
It's Swifty! Swifty, you toad sucker!
Re: Bent / broken push rods [Re: zrxkawboy] #1175166
02/09/12 09:23 PM
02/09/12 09:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Dude that motor needs to be torn down, sorry. The heads have to come off, the cam needs to come out and the pan needs to be dropped. No getting around it. You could have bent the valves, wiped the cam and damaged the pistons. You can't see much w/ those little "scope" cameras. It would stink to heck to put it all togther and have the same thing happen at fire up or to find out the cam was wiped.
I've been where you are I had 200 miles on a brand new engine when it dropped a valve(I/we think the cam walked) At least you can fix yours. I ruined 2 cylinders, 2 pistons, filled the crank case w/ water and toasted 2 valve seats on a super nice set of iron heads.
Grab a 12 pack and get rolling.
Coming soon!!!!
