Stupid fender tag question #1174761
02/08/12 06:25 PM
02/08/12 06:25 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
OK, like most of us, I like to look at fender tags for the thrill of the hunt. So this one might be a stupid question. How come fender tags don't read power steering on the tags, or do they? I've seen a bunch of cars that have power with no such code. What is the code and is it always there?
Re: Stupid fender tag question [Re: DANA60] #1174762
02/08/12 06:40 PM
02/08/12 06:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The fender tag is basically the instructions for building & trimming the painted body.
A broadcast sheet wouldn't survive the welding, dip & paint process and remain readable.
NO - power steering would NOT be coded on a fender tag.
Re: Stupid fender tag question [Re: 6bblgt] #1174763
02/08/12 06:48 PM
02/08/12 06:48 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
OK that sounds right. So without build sheet, tough luck. I do see that a power brake code is there, how 'bout that?
Re: Stupid fender tag question [Re: DANA60] #1174764
02/08/12 07:08 PM
02/08/12 07:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Fender tag layout was changed/modified from year-to-year, plant-to-plant & model-to-model.
To comprehend why a specific code was used (wasn't used) on a specific model year car you would have to ask a very specific question.
Using NEVER & ALWAYS usually causes problems/issues.
Re: Stupid fender tag question [Re: DANA60] #1174765
02/08/12 07:38 PM
02/08/12 07:38 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How about what ?
Also which codes make the tag are plant dependent.
Re: Stupid fender tag question [Re: JohnRR] #1174766
02/08/12 11:30 PM
02/08/12 11:30 PM
midwest
68427vette Offline
68427vette  Offline
midwest
b41 b51 i think?? brakes
Re: Stupid fender tag question [Re: 68427vette] #1174767
02/08/12 11:59 PM
02/08/12 11:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Occasionally power steering is coded on a fender tag - if it is part of an option group.
A04 from the 1969 - 1971 model years included power steering as an example.
Re: Stupid fender tag question [Re: Alaskan_TA] #1174768
02/09/12 01:56 AM
02/09/12 01:56 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Tilt -A-Scope steering column would be another secondary indication of power steering.
Most A04 packages did included PS but there are a couple of examples of Basic Groups that don't. The Imperial doesn't because PS was standard on the model. 69 Valiant Basic Group doesn't include PS either.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Stupid fender tag question [Re: 69CoronetRT] #1174769
02/09/12 02:38 AM
02/09/12 02:38 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Isn't the tag for color, trim and things that require certain body part configurations, holes and brackets?
Re: Stupid fender tag question [Re: NicksGarage] #1174770
02/09/12 03:12 AM
02/09/12 03:12 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Basically yes.
It is curious as to why there was so much variation in what was coded between plants. Why is LR so sparse yet other plants list a lot of things? Why do C bodies have a different coding format than A bodies?
You would think the way cars were built was fairly standardized between plants. Why weren't fender tags?
Seeking:
Re: Stupid fender tag question [Re: 68427vette] #1174771
02/09/12 06:17 AM
02/09/12 06:17 AM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
What year did they start putting both these codes on cars'?
More specifically St. Louis cars.
I have 2-3 tags from St.L '72 showing both codes so I figured it must be '72?
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: Stupid fender tag question [Re: Alaskan_TA] #1174772
02/09/12 10:58 AM
02/09/12 10:58 AM
JohnRR Offline
JohnRR  Offline
I'm pretty sure my 69 Bee is A04 , lynch rd. built , but it doesn't have power steering . It does have A31 , Same with my 69 Dart GTS , A 04 , A31 , no power steering .
