Re: Stupid fender tag question
[Re: DANA60]
#1174765
02/08/12 07:38 PM
02/08/12 07:38 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
OK that sounds right. So without build sheet, tough luck. I do see that a power brake code is there, how 'bout that?
How about what ?
Also which codes make the tag are plant dependent.
[Re: Alaskan_TA]
#1174772
02/09/12 10:58 AM
02/09/12 10:58 AM
JohnRR
Occasionally power steering is coded on a fender tag - if it is part of an option group.
A04 from the 1969 - 1971 model years included power steering as an example.
I'm pretty sure my 69 Bee is A04 , lynch rd. built , but it doesn't have power steering . It does have A31 , Same with my 69 Dart GTS , A 04 , A31 , no power steering .
