2002 Durango motor swap? #1174677
02/08/12 01:02 PM
02/08/12 01:02 PM
Twin Cities, MN
MN-ScatPack Offline OP
Twin Cities, MN
I am looking at a 2002 Durango in really good condition with the exception of the motor. It has a 4.7l that needs work. Is it possible to swap the 4.7l for the 5.9l without changing to much stuff?
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174678
02/08/12 01:09 PM
02/08/12 01:09 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Nope. Harness, computer, exhaust, if you want to do it make sure you find a complete 5.9 Durango to strip
Re: 2002 Durango motor swap? [Re: GTXKen] #1174679
02/08/12 04:50 PM
02/08/12 04:50 PM
Twin Cities, MN
Twin Cities, MN
So if I get a complete engine, will it be a direct swap with the trans, wiring harness, etc...?
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174680
02/08/12 05:15 PM
02/08/12 05:15 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
no. you need ALL that stuff from the donor vehicle to do the swap.
the 4.7s and 5.9s are totally different, and nothing interchanges between the 2, however, since you COULD get a 5.9 Durango in the same years as a 4.7 Durango, then you can get all the stuff you need from a donor truck.
Might even be able to use a Dakota R/T of the same year for the donor parts.
I don't know enough about the transmissions to say for sure, but I know for a fact the engine harness and PCM has got to be changed. 5.9s used distributors, 4.7s use coil packs.
**Photobucket sucks**
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174681
02/08/12 05:24 PM
02/08/12 05:24 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
And if you're on the lucky side, the 4.7 may have just tossed a rocker arm w/out ruining the cyl head. Somewhat common on 4.7 and 3.7 engines. If it's a matter of lower end problem, it may be worth fixing the orig 4.7. If you ever had a 4.7, you would probably like it.
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174682
02/08/12 05:28 PM
02/08/12 05:28 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Trans is completely different, 4.7L used the 45RFE, 5.9 used 46RE. You need the entire powertrain, wiring, and controller to make it work. You are probably much farther ahead buying a used/reman 4.7L and simply swapping the engine.
The 4.7L will get you better MPG and combined with the deep first gear in the 45RFE you won't have any better performance. The only difference would be if you are towing the 5.9L is a little better because of the greater torque.
It's a little known fact that the 1st Gen Durango R/T's were one of the slower Durango models; they had no real boost in power and were saddled with AWD and the heavier 17" tires.
Re: 2002 Durango motor swap? [Re: 73MagDuster] #1174683
02/08/12 05:56 PM
02/08/12 05:56 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That's what I thought, but I wasn't sure if there was a way to adapt the 46RE to work with the 4.7, or vice versa.
Re: 2002 Durango motor swap? [Re: 70Cuda383] #1174684
02/08/12 08:53 PM
02/08/12 08:53 PM
Twin Cities, MN
Twin Cities, MN
So would you have any issue buying a 2002 with a 4.7 vs. the 5.9? I did have a grand cherokee with the 4.7 and was ok with it. Same with the durango?
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174685
02/08/12 10:42 PM
02/08/12 10:42 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
I wouldn't, in fact I would prefer it. The Gen I Dingo with a 4.7L is a nice rig all around. A Gen II with a 4.7L is a different story.
Re: 2002 Durango motor swap? [Re: 73MagDuster] #1174686
02/08/12 11:53 PM
02/08/12 11:53 PM
Twin Cities, MN
Twin Cities, MN
What yrs are gen I vs. gen II?
Re: 2002 Durango motor swap? [Re: MN-ScatPack] #1174687
02/09/12 10:05 AM
02/09/12 10:05 AM
chicagoland,usa
chicagoland,usa
2000 thru 2003.
Re: 2002 Durango motor swap? [Re: buildanother] #1174688
02/09/12 11:56 AM
02/09/12 11:56 AM
GTXKen Offline
super gas
GTXKen  Offline
super gas
I liked my Gen I with the 5.2, very reliable motor. I have known several people who have had valve-train issues with the 4.7L in the Durango and Dakota
Re: 2002 Durango motor swap? [Re: GTXKen] #1174689
02/09/12 12:34 PM
02/09/12 12:34 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the 5.2s and 5.9s are known to be good up to 200K miles, some even beyond.
I've had an 05 Durango 4.7 and had no problems at all in the 60K miles I put on it. bought it new and never had a problem. towed with it and it did fine too.
now I have an 04 Dakota with the 4.7, it's got 80K miles on it now, and haven't had any issues with it.
when it blows up, or gets valve train problems like everyone says they do, i'll post it up here, but I have a feeling the problems were only on the earlier 4.7s, (like the one in your ride now) where they had some PCV issues and the top ends would sludge up from water vapor. there was a fix that they did, I think in 03, which fixed the problem.
I've also heard that at some point, something inside the 4.7s changed, a tone ring on the crank or something, so you cannot take a later engine and put it into an earlier vehicle, without opening up the engine, removing the crank and changing the tone ring. I don't know the exact specifics, but I've heard of guys having that problem
Re: 2002 Durango motor swap? [Re: 70Cuda383] #1174690
02/09/12 11:56 PM
02/09/12 11:56 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
In 2002 They changed the engine controler. Also the timing chains and water pumps.
Re: 2002 Durango motor swap? [Re: rt66jim] #1174691
02/10/12 05:30 PM
02/10/12 05:30 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
2001 and prior engines had a 16 tooth tone ring,2002 and later had a 32 tooth tone ring,have to remove the crank to change them
