Re: How much labor cost for a front strut replacement?
[Re: V194]
#1174625
02/08/12 12:37 PM
02/08/12 12:37 PM
Posts: 19,872 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
My Mitchell's guide says 1.3 hours per strut, or 2.4 for the pair, with a .7 deduction per strut if the knuckle is removed.
It's VERY common for the tops of the strut towers to rot out on those vehicles. If yours has, you'll need to get that fixed, too. There's a repair kit out there for that specific purpose because it's such a common occurrence.
Earning every penny of that moderator paycheck.
DBAP
[Re: V194]
#1174627
02/08/12 04:37 PM
02/08/12 04:37 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I agree quick struts.By the time you uy struts bearing plates and labor they are cheap.Installed the last set on my nieces dodge mini in about 1/2 hour.No special tools needed.Took me longer to put the car on stands and take it off than to replace them.Rocky
Chrysler Firepower
[Re: GTXKen]
#1174628
02/08/12 05:52 PM
02/08/12 05:52 PM
Posts: 3,109 SC
V194
SC
You can get a quick strut for around $200 each that includes the strut, spring, bearing and isolators all assembled. Take it somewhere and once they get it apart they are going to tell you you need all that stuff anyway. Super easy to change yourself.
Never done a set how hard is it? I have air tools and a concrete floor heated garage, No lift however.
