Trans leak 727 auto #1174264
02/07/12 11:37 PM
02/07/12 11:37 PM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
Car has sat for 6 or 8 mo. Ran maybe once. I had trans leak, determined selector shaft seal, replaced, about 2 wks. ago, dry! Woo Hoo! Then did header swap, exhaust redo, fired up today first time. Checked cooler lines also suspect, good! Then after shutting down, OHH _____! After runnign about 30 minutes, drips from bellhousing. I'm fearing front pump seal, but hoping maybe from sitting so long. Will it seal up after some run time? I have type F fluid, Dexron help? Any of those transmission "stop leak" additives work? I just put the X-pipe exhaust back together.
Help?
jim.
Re: Trans leak 727 auto [Re: bacaruda] #1174265
02/08/12 12:17 AM
02/08/12 12:17 AM
United States
F. Sadler Offline
F. Sadler  Offline
United States
I would run it for a wile and just keep a close eye on it...I dont put stop leak crap in nothing...
Re: Trans leak 727 auto [Re: F. Sadler] #1174266
02/08/12 12:20 AM
02/08/12 12:20 AM
crisfield, maryland 21817
8
82ramIndy493 Offline
Try some LUCAS trans additive. Great stuff. If it doesn't work you may have to pull the tranny and reseal it.
Re: Trans leak 727 auto [Re: 82ramIndy493] #1174267
02/08/12 01:21 AM
02/08/12 01:21 AM
WV
bacaruda Offline OP
bacaruda  Offline OP
WV
Thanks, Sadler I'll try that first have some small exhaust leaks to fix. And then, if it's still there I'll try indy's advice. Trying to sell, don't want to break the time bank!
Re: Trans leak 727 auto [Re: bacaruda] #1174268
02/08/12 09:19 PM
02/08/12 09:19 PM
BDW Offline
BDW  Offline
I'd take a look at the pivot rod too while you're under there.
