Car has sat for 6 or 8 mo. Ran maybe once. I had trans leak, determined selector shaft seal, replaced, about 2 wks. ago, dry! Woo Hoo! Then did header swap, exhaust redo, fired up today first time. Checked cooler lines also suspect, good! Then after shutting down, OHH _____! After runnign about 30 minutes, drips from bellhousing. I'm fearing front pump seal, but hoping maybe from sitting so long. Will it seal up after some run time? I have type F fluid, Dexron help? Any of those transmission "stop leak" additives work? I just put the X-pipe exhaust back together.
Help?
jim.
