Should I sleeve master cylinder? #1174125
02/07/12 06:08 PM
02/07/12 06:08 PM
Iowa
dsp Offline OP
dsp  Offline OP
Iowa
I have a master cylinder that needs rebuilt. If it is excessively pitted, should I consider sleeving it? White Post Restorations sleeves with brass. Karp's Brake Service sleeves with 304 stainless steel. Anyone have experience with either of these companies? Any other recommendations?
Re: Should I sleeve master cylinder? [Re: dsp] #1174126
02/07/12 08:51 PM
02/07/12 08:51 PM
yes if the car is all original & you want to keep that original M/C on the car & useable. As you know wont be cheap. No exp w either co but WP has been around forever EDIT are you sure it IS the orig M/C? & never been replaced in the cars' lifetime
Re: Should I sleeve master cylinder? [Re: RapidRobert] #1174127
02/07/12 09:58 PM
02/07/12 09:58 PM
Iowa
dsp Offline OP
dsp  Offline OP
Iowa
Yes, it is the original master cylinder. Has never been rebuilt. My parents bought the car new in 1973 and I've wrenched on it ever since. Master cylinder still works but has a slow leak. I would like to rebuild the original if possible, however, the bore may be too pitted to save. Sleeving seems to be a good option but would like to get some opinions from others. White Post has advertised brass sleeving for years, but I saw this recent ad for Karp's and stainless steel sleeving. Any advice?
Re: Should I sleeve master cylinder? [Re: dsp] #1174128
02/07/12 10:20 PM
02/07/12 10:20 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I use Brake and Equipment warehouse in Minneapolis and they use steel sleeves. Never had a problem with the master cylinders after I've rebuilt them and installed on a car, the one on my convertible has been on there is coming up on 5 years since I had it sleeved.
If the exterior of your original master cylinder and the reservoir are in good shape, I'd say go ahead and have your bore sleeved.
