Trick to installing valley pan gasket???
#1173769
02/07/12 11:20 AM
02/07/12 11:20 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Is there a trick to installing this when using the 4 paper gaskets? I couldn't line up the bolt holes because of the increased thickness. I had sealed the gaskets to both sides of the pan so it would go on as 1 piece. Do I only need to use gaskets on 1 side? If so, which side? Thanks
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
Re: Trick to installing valley pan gasket???
[Re: JohnRR]
#1173771
02/07/12 11:31 AM
02/07/12 11:31 AM
Plum440
Slidell, LA
They look to be standard gaskets and do not appear thin at all. Not sure of the MFG of the pan, it was with the rebuild kit my machine shop used to assemble the long block. I want to buy a new one and not reuse it.
[Re: JohnRR]
#1173773
02/07/12 11:46 AM
02/07/12 11:46 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Some swear by them I swear at the papers.Ive installed them with just tins since the 60s and never had a problem.My 440 has alumimum heads and intake and my kids iron and aluminum intake.Both have been together for years and no problems.Ive run aluminum intakes since the 60s with just the tins.Ive pulled tons of BBs from the factory and never seen papers.I just use some RTV under the hold down rails and a dab in the 4 corners.To me osing the paers is like wearing suspender and a belt.If you have a leak something isnt right.Rocky
Chrysler Firepower
[Re: Plum440]
#1173774
02/07/12 11:46 AM
02/07/12 11:46 AM
RapidRobert
In alot of cases they add too much thickness as you've found out unless the heads' intake faces are milled. I'd take em off & use a very light even smear of Permatex #2 in the toothpast like tube around both sides of each of the 8 port openings in the valley pan tin gasket. people have used them dry if the surfaces are dead flat/perfect matching angles but the Permatex works for me. the thick ones ain't cut perfect and a guy on here sells .015" thin ones & I ain't bought em (yet) but his supplied measurements fit the port dimention perfectly & if good I'll spray them w Permatex "high tack" the red spray gasket sealer. It's light, sprays on easily/evenly and is extremely tacky
[Re: JohnRR]
#1173775
02/07/12 11:55 AM
02/07/12 11:55 AM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
The standard paper is usually way too thick. The more correct thin paper is available. I think it's even on Ebay. BUT, and this is a huge BUT, most of the time you don't need the paper at all. The factory did not use the paper. It will seal fine with just a couple of coats of copper coat spray or aluminum spray paint. I normally only use the paper if the manifold has been cut to fit a different engine and needs the extra thickness to work on this engine. With a choice of no gaskets, thin gaskets or thick gaskets you can ussually get a good fit. I set the manifold on with a smashed down used pan and check the bolt holes. If they line up good then put a new pan on it with no paper. If the manofold holes are lower than the head holes then add the appropriate paper. If the manifold holes are too high then machine work will be required either to the manifold or the manifold side of the heads (paper can't fix that).
[Re: GomangoCuda]
#1173776
02/07/12 12:22 PM
02/07/12 12:22 PM
Posts: 15,487 Florida
scratchnfotraction
member TOPSIDE sells the thinner gasket cheap. IMHO after chasing a intake leak for the first 3 months my 440 was in the truck,i wount do it again with out the gaskets. i used the felpro HP 1215 VP with 4 gaskets,stock heads uncut/weiand alum intake uncut. but with a new pan you do have a good chance at the seal,the embossed tin will flaten out and seal..i just would not try it a 2nd time.
[Re: therocks]
#1173777
02/07/12 12:36 PM
02/07/12 12:36 PM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
I swear at the papers. I just use some RTV under the hold down rails and a dab in the 4 corners.
