Max wedge ports #1173436
02/06/12 08:17 PM
02/06/12 08:17 PM
Bowling Green, KY
cudaboy Offline OP
cudaboy  Offline OP
Bowling Green, KY
What is the physical size difference between MW ports and standard ones?
I am going to be buying a crossram intake for my NSS car, and am not sure which one to buy. I need to pull my current intake off and see if the ports have been hogged out or not. The guy I bought the car from said the heads were ported, but wasn't sure to what extent.
thanks
Dennis
Re: Max wedge ports [Re: cudaboy] #1173437
02/06/12 08:26 PM
02/06/12 08:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Few guys take their ports all the way open to max wedge size. It's a substantial increase in port size and not the right move for everyone.
Re: Max wedge ports [Re: cudaboy] #1173438
02/10/12 01:38 AM
02/10/12 01:38 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
if they are still stock size I suggest A&A transmission they make a x-ram in both max wedge and non- max port ,not to bad on price also, I myself used the eddy victor max heads and a stage II manifold on my engine with 2 holleys.
Re: Max wedge ports [Re: cudaboy] #1173439
02/10/12 06:22 PM
02/10/12 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a MW gasket on a 906 head. If the top of the port on some factory castings is cut to the gasket size the raised surface gets thin or non-existent.
