Battery Toppers #1172936
02/05/12 11:05 PM
02/05/12 11:05 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
OK, I'm trying to get info on using a battery topper for a 69 GTX. I'm getting different signals. I know that a topper is lightly wider and that the battery holder probably won't fit.
Is www.batterytoppers.com/ the only vendor of these toppers?
Can I get a battery at Walmart or Costco that will fit under the topper?
Will I need the post extenders?
Re: Battery Toppers [Re: moparcanuk] #1172937
02/05/12 11:27 PM
02/05/12 11:27 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..you can bend a "Z" style battery strap to fit..('68,'69?)
..the '70 straight style is not wide enough,you'll have to make a new one about a 1/2" wider
..there are standard top post batteries that fit fine.
Re: Battery Toppers [Re: can.al] #1172938
02/05/12 11:29 PM
02/05/12 11:29 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
waste of time
Re: Battery Toppers [Re: moparcanuk] #1172939
02/06/12 12:53 AM
02/06/12 12:53 AM
Not sure the Q but when I worked in a tune up shop at least half if not more of the batteries that ended up needing replacement were unsecured in the box & the flopping around/vibration over time killed them
