battery disconnect #117285
09/08/08 02:15 PM
09/08/08 02:15 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
a) can you tell which is the positive and negative from these pic and b) if the positive is disconnected, is it totally wrong/sketch?
Re: battery disconnect [Re: Hank] #117286
09/08/08 02:18 PM
09/08/08 02:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Pos is the right hand post in the picture. Always the larger post. Yes it is the + that is disconnected. Should also be stamped on the battery case.
Re: battery disconnect [Re: MoparforLife] #117287
09/08/08 02:19 PM
09/08/08 02:19 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
Shouldn't the disconnect be on the negative side?
Re: battery disconnect [Re: Hank] #117288
09/08/08 02:40 PM
09/08/08 02:40 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Intelligent people can disagree, but...
a quick disconnect such as pictured can be done on either the positive side (in my experience, the more common location) OR on the negative side.
What might be confusing for some people is the absolute rule when wrenching off battery connections. In that case, you always undo the negative first and reconnect it last, so that you cannot inadvertently do a dead short between a ground point and the positive post of a fully connected battery.
(This all assumes you are not working on an ancient British car with positive earth.)
Down to just a blue car now.
Re: battery disconnect [Re: 68HemiB] #117289
09/08/08 02:49 PM
09/08/08 02:49 PM
the left coast
Hank Offline OP
Hank  Offline OP
the left coast
Thanks! Funny, I just found this post on the HAMB. Looks like people do disagree on this.
http://www.jalopyjournal.com/forum/showthread.php?t=211450
Re: battery disconnect [Re: 68HemiB] #117290
09/08/08 02:49 PM
09/08/08 02:49 PM
Upper Midwest
Upper Midwest
Or a up to mid 50's model of a lot of domestics including Ford had + ground. A lot of vehicles and implements of that era had + ground.
Re: battery disconnect [Re: MoparforLife] #117291
09/08/08 03:48 PM
09/08/08 03:48 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Either is fine, period. What I have found is that most disconnects I have bought only fit well on the negative post, because many batteries have a smaller negative post than positive.
