Just fired up my new 440 - Holley questions #1172836
02/05/12 10:18 PM
02/05/12 10:18 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I just fired up my new 440 and it ran like crap. When I first fired it up I had fuel coming out both carb vents . I adjusted the floats what felt like all the way down ( turned nut clockwise ) before it stopped pumping fuel out of the vents ( Mechanical pump ).I haven't had a chance to pull the float level plugs to check the level with the motor running yet. The motor runs really rough like it has a couple dead cylinders but the exhaust temps ( taken at the header flanges ) are fairly consistent about 325 - 400 F. It idles just OK but when I rev it it has that dead cylinder shake to it. It did pop through the carb when I first tried to start it the dist was 180 out. I screwed the mixture screws all the way in and the motor died so I think the power valve is ok. The carb is a Holley 4780-5. The motor is new and everything on it is new or rebuilt. Is this a carb problem or could it be something else?
Motor info:
452 peanut plug heads
9.7:1 compression
Hughes whiplash muscle car cam
Performer rpm intake
MSD-6 AL
Stock dist
Blaster coil
Holley 4780-5 Carb. This carb was rebuilt by a meathead that put the metering blocks on backwards
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172837
02/05/12 10:28 PM
02/05/12 10:28 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
im not happy with my holley carb to..keep on it, im sure all it needs is tuned up and adjusted properly.
Re: Just fired up my new 440 - Holley questions [Re: Dakota_Don] #1172838
02/05/12 10:32 PM
02/05/12 10:32 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I just pulled a spark plug and it's black and wet.I only ran this motor for 20 minute break in and then maybe another 5 minutes after that. The plugs are Autolite 23's is that too cold for this motor ?
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172839
02/05/12 10:37 PM
02/05/12 10:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What kind of pressure is that pump putting out?
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172840
02/05/12 10:37 PM
02/05/12 10:37 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what is your fuel preasure ?
you do not want over 7 psi max 1
what pump ?
what is timing set to?
idel speed start at 800.
vac with trans in d warm is ?
Re: Just fired up my new 440 - Holley questions [Re: calrobb2000] #1172841
02/05/12 11:21 PM
02/05/12 11:21 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and did you take it apart and check thing out before firing up the engine....
the needle and seat probably had dirt in it...usually tapping on the housing will unclog it..or brake cleaner will work too...
Tony
70 AARCuda Vitamin C
Re: Just fired up my new 440 - Holley questions [Re: 70AARcuda] #1172842
02/06/12 01:00 AM
02/06/12 01:00 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I tried tapping on the bowls but they continued spraying the next time I started it. it's a stock mechanical pump my Holley inline gauge is reading 3-4 psi while the engine is running.
Re: Just fired up my new 440 - Holley questions [Re: 70AARcuda] #1172843
02/06/12 01:02 AM
02/06/12 01:02 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I did take it apart to switch the metering blocks around and everything looked OK but I didn't go over every part like maybe I should have.
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172844
02/06/12 01:02 AM
02/06/12 01:02 AM
I'd go thru the carb & just me I'd take off the intake & regoop the cam/lifters
Re: Just fired up my new 440 - Holley questions [Re: calrobb2000] #1172845
02/06/12 01:06 AM
02/06/12 01:06 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
The timing was at 34 - 35 at 2,000 rpm with the vacuum advance disconnected and plugged during break in. After break in I set it at 10 with the vacuum line disconnected to try and figure out what was going on.
Re: Just fired up my new 440 - Holley questions [Re: RapidRobert] #1172846
02/06/12 01:09 AM
02/06/12 01:09 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Rapid ..... I was able to complete the cam break in before it really started running like crap. Do you think it would be worth pulling the intake off to "goop the lifters" ?
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172847
02/06/12 01:10 AM
02/06/12 01:10 AM
No you're good there Bro.
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172848
02/06/12 01:26 AM
02/06/12 01:26 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
What should I look for in the carb ? I've re-built a few Holley's but I'm not even close to being an expert on them so any guidance would be a great help.
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172849
02/06/12 01:41 AM
02/06/12 01:41 AM
You'd wanna correct his mistakes (the blue no stick gaskets are good) then invert each bowl & set the float level w a drill bit(s) (forget the dimentions). On a real wild cam I'd rather use the drill bits for a first/last adjustment. EDIT alot of people overtighten jets and undertighten PV's, not crazy just a bit
Re: Just fired up my new 440 - Holley questions [Re: RapidRobert] #1172850
02/06/12 02:42 AM
02/06/12 02:42 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Take the bowls off. Turn them upside down and adjust the needle and seat to where the floats are level. This will get you real close.
What are the primary jets? Aset of 70/72s would be a good starting point. What is the power valve. Take a vac reading, divide that number by 2. Thats the power valve you need.
I am truckless..
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172851
02/06/12 03:00 AM
02/06/12 03:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's going to run poorly until you get the timing dialed in. Been there, done that. Trust me. I can't see that whiplash cam liking only 10* of initial timing. I ran more initial than that with a stock cam.
Try bumping your initial up to like 16 and go from there. Then play with the timing and see how much timing you can add before the engine starts to fight against the starter. This happens when the engine is hot and you crank the starter. You will be able to tell when you get to this point. Then back the distributor off a hair and lock it down. After that you will probably need to recurve your distributor to get the total timing to 36-38* all in somewhere around 2600-2800rpm.
Remember, timing affects fueling. Fueling does not affect timing. So obviously you get the timing setup correctly first. Half-assing it to do the cam break-in is fine, we all do it that way. But now is the time to get that setup correctly before you try additional carb tuning IMO.
Re: Just fired up my new 440 - Holley questions [Re: 340SHORTY] #1172852
02/06/12 08:42 AM
02/06/12 08:42 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
340Shorty ... The power valve is a 6.5 primary jets are 71 secondary jets are 85
Re: Just fired up my new 440 - Holley questions [Re: DaytonaTurbo] #1172853
02/06/12 08:54 AM
02/06/12 08:54 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Daytona ... The fuel squirting out of the bowl vents has me going after the carb first after 30 minutes of run time the plugs were wet and black so I think the floats are screwed up. Adjusting the the float level externally had little to no affect so something must be wrong in there. I plan on pulling the bowls off this morning and checking the floats then I will fire it up and work on getting the timing right. I hope it will even run after fuel soaking the plugs.
Re: Just fired up my new 440 - Holley questions [Re: 73rrak] #1172854
02/06/12 10:50 AM
02/06/12 10:50 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Pull the needle/seat assemblies and clean the rubber seats. You might have some garbage in them that may not have allow them to close. Then re-adjust your floats.
Re: Just fired up my new 440 - Holley questions [Re: YO7_A66] #1172855
02/06/12 01:23 PM
02/06/12 01:23 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Im assuming you double checked that you dont have a plug wire(s) crossed?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
