Re: Just fired up my new 440 - Holley questions
[Re: Dakota_Don]
#1172838
02/05/12 10:32 PM
02/05/12 10:32 PM
Posts: 340 Alaska
73rrak
Alaska
I just pulled a spark plug and it's black and wet.I only ran this motor for 20 minute break in and then maybe another 5 minutes after that. The plugs are Autolite 23's is that too cold for this motor ?
[Re: 73rrak]
#1172840
02/05/12 10:37 PM
02/05/12 10:37 PM
Posts: 1,999 s. e. pa.
calrobb2000
s. e. pa.
hi what is your fuel preasure ? you do not want over 7 psi max 1 what pump ? what is timing set to? idel speed start at 800. vac with trans in d warm is ?
[Re: calrobb2000]
#1172841
02/05/12 11:21 PM
02/05/12 11:21 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Holley 4780-5 Carb. This carb was rebuilt by a meathead that put the metering blocks on backwards
and did you take it apart and check thing out before firing up the engine....
the needle and seat probably had dirt in it...usually tapping on the housing will unclog it..or brake cleaner will work too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 73rrak]
#1172844
02/06/12 01:02 AM
02/06/12 01:02 AM
RapidRobert
I'd go thru the carb & just me I'd take off the intake & regoop the cam/lifters
[Re: RapidRobert]
#1172846
02/06/12 01:09 AM
02/06/12 01:09 AM
Posts: 340 Alaska
73rrak
Alaska
Rapid ..... I was able to complete the cam break in before it really started running like crap. Do you think it would be worth pulling the intake off to "goop the lifters" ?
[Re: 73rrak]
#1172847
02/06/12 01:10 AM
02/06/12 01:10 AM
RapidRobert
No you're good there Bro.
[Re: 73rrak]
#1172849
02/06/12 01:41 AM
02/06/12 01:41 AM
RapidRobert
You'd wanna correct his mistakes (the blue no stick gaskets are good) then invert each bowl & set the float level w a drill bit(s) (forget the dimentions). On a real wild cam I'd rather use the drill bits for a first/last adjustment. EDIT alot of people overtighten jets and undertighten PV's, not crazy just a bit
[Re: RapidRobert]
#1172850
02/06/12 02:42 AM
02/06/12 02:42 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Take the bowls off. Turn them upside down and adjust the needle and seat to where the floats are level. This will get you real close.
What are the primary jets? Aset of 70/72s would be a good starting point. What is the power valve. Take a vac reading, divide that number by 2. Thats the power valve you need.
I am truckless..
[Re: 73rrak]
#1172851
02/06/12 03:00 AM
02/06/12 03:00 AM
DaytonaTurbo
Manitoba, Canada
It's going to run poorly until you get the timing dialed in. Been there, done that. Trust me. I can't see that whiplash cam liking only 10* of initial timing. I ran more initial than that with a stock cam. Try bumping your initial up to like 16 and go from there. Then play with the timing and see how much timing you can add before the engine starts to fight against the starter. This happens when the engine is hot and you crank the starter. You will be able to tell when you get to this point. Then back the distributor off a hair and lock it down. After that you will probably need to recurve your distributor to get the total timing to 36-38* all in somewhere around 2600-2800rpm. Remember, timing affects fueling. Fueling does not affect timing. So obviously you get the timing setup correctly first. Half-assing it to do the cam break-in is fine, we all do it that way. But now is the time to get that setup correctly before you try additional carb tuning IMO.
[Re: 73rrak]
#1172854
02/06/12 10:50 AM
02/06/12 10:50 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Pull the needle/seat assemblies and clean the rubber seats. You might have some garbage in them that may not have allow them to close. Then re-adjust your floats.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1172855
02/06/12 01:23 PM
02/06/12 01:23 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Im assuming you double checked that you dont have a plug wire(s) crossed?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: 73rrak]
#1172857
02/06/12 03:26 PM
02/06/12 03:26 PM
dogdays
First of all set the floats, upside down and level is indeed a good starting point.
Idle metering screws at 1 1/2 turns out.
Next, your rear jets are WAAY too big. Mid '70s would be more like it. Stock is 76, and most Holleys are set up pretty close out of the box.
then work on timing.
R.
[Re: dogdays]
#1172858
02/06/12 03:49 PM
02/06/12 03:49 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
R.
I'll go one further, set the floats a tad low... Then turn the mixtures crews in all the way and back out 1.25, start it and run the romps up to 2200 ste your timing in full at 36-38* ley it run for a few minutes, back it down to 800rpm and set you mixtures screws for best vaccuum. Then go out and waffle it...if it stumples you might need to adjust your pump shot or vaccuum springs.
[Re: dogdays]
#1172861
02/06/12 07:14 PM
02/06/12 07:14 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
In my reading on Holly carbs, on a vac carb the rear jetting can vary up to 10 sizes larger than the front if they are changeable. this has worked very well in my apps
I dont run DP carbs but on them the secondary jetting is the same size as the primaries.
of coarse there may be curcumstances where this doesnt apply.
I am truckless..
[Re: 73rrak]
#1172875
02/07/12 09:14 AM
02/07/12 09:14 AM
Mr.Yuck
Brookeville, Md
Ok I will keep going with this one. I took the valve covers off and all of the intake push tubes are bent and some are completely off the rockers. One is broken I think and is laying down in the valley. What would cause this ?
ouch you bent up your push rods? This would cause your "running like doo doo" problem. A few things can cause this, stuck valves, over-tighten the rocker shafts, to tight of a lash (id you have adjustables), wrong push rods... timing chain issue, wiped cam You said it was running fine before correct?
