Re: Dual res mastercylinder conversion?
[Re: bigblk66_coronet]
#1172833
02/05/12 10:00 PM
02/05/12 10:00 PM
RapidRobert
for an iron M/C, one for a 67-69 4 wheel drum manual brakes in that car line will work fine/simple. An alum one of the proper bore dia/manual brakes w an adapter plate & maybe will require an adapter fitting or 2 for the M/C.
[Re: RapidRobert]
#1172834
02/05/12 10:55 PM
02/05/12 10:55 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I use 69-70 masters for a C body on all the ones I do.My kids 62 300 4 whl drums is 12 years and my 65 B is 10 years with disc drum.No problems ever with them.Just make sure it a drum master not a disc.Rocky
Chrysler Firepower
[Re: therocks]
#1172835
02/06/12 01:30 AM
02/06/12 01:30 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Yes. I updated my 66 Charger with a reman unit from Autozone. I think it was around $25. Works perfectly. As stated, get a replacement part # for '67 with the same size brakes/wheel cylinders you have. Just keep in mind, you will need a matching distribution block and different lines going to the master cylinder.
