68 GTX Sway Bar Bushing replacement #1172765
02/05/12 07:42 PM
02/05/12 07:42 PM
East KY
N
nbbcrh Offline OP
nbbcrh  Offline OP
N
East KY
Gentlemen, need your help on replacing original type front sway bar bushing in the original brackets, bought 15/16 Energy Suspension bushing, I've done everything possible, is there a trick out there? Do I have the wrong size, it's definitely a 68 GTX sway bar, should I have gotten the 7/8 bushing? Help
Thanks Ben
Re: 68 GTX Sway Bar Bushing replacement [Re: nbbcrh] #1172766
02/05/12 08:40 PM
02/05/12 08:40 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
The method that i use, and others, is to cut the weld on one side of the bracket.
Bend the bracket back far enough to slide the bushing in, where it needs to be.
Re-weld the bracket back together.
I really think that's the only way your gonna get a bushing replaced, in one of those sway bars.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 68 GTX Sway Bar Bushing replacement [Re: hemi71x] #1172767
02/05/12 09:14 PM
02/05/12 09:14 PM
East KY
N
nbbcrh Offline OP
nbbcrh  Offline OP
N
East KY
Thanks Jim, that's about the only way I could see doing it with the original brackets, I thought about buying a kit for the original sway bar but can't figure which one is would be best. I appreciate your response, that's what I'll do, by the way my brother when he was in Air Force used to fly a F4-E Phantom (wild weasel) looks like your pic of plane
