Holley Ultra Str. Avenger carb r Morain filters needed #1172605
02/05/12 04:42 PM
02/05/12 04:42 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Am out in garage finishing up plumbing fuel system, went to install dual inlet fuel line into carb, morain in line filters are stopping the fuel line to thread into carb, take out the copper Morain filters and it threads just fine.
Do I need these? I have two in-line filters now. One between tank and pump and one between pump and carb and the sock in the tank as well.
Thnx Chuck
BTW the Morain filters are those copper screen type plugs that are in the I guess you call in fuel bowl
Re: Holley Ultra Str. Avenger carb r Morain filters needed [Re: moparrulzzz] #1172606
02/05/12 04:45 PM
02/05/12 04:45 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you have a filter in the fuel line you won't need them.
Re: Holley Ultra Str. Avenger carb r Morain filters needed [Re: 451Mopar] #1172607
02/05/12 04:47 PM
02/05/12 04:47 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx ,just wanted to have some one tell me it was ok to leave them out, that was what I thought since I have other filters in place!!
Re: Holley Ultra Str. Avenger carb r Morain filters needed [Re: moparrulzzz] #1172608
02/05/12 04:51 PM
02/05/12 04:51 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just bought the 770 Ultra street avenger carb, and was a little disappointed that it did not have screw in restrictors in the metering blocks.
Re: Holley Ultra Str. Avenger carb r Morain filters needed [Re: 451Mopar] #1172609
02/05/12 11:24 PM
02/05/12 11:24 PM
Mansfield,Ohio
Mansfield,Ohio
Thats all Chinese to me What do they do? I am new too all this!!
Re: Holley Ultra Str. Avenger carb r Morain filters needed [Re: moparrulzzz] #1172610
02/06/12 12:58 AM
02/06/12 12:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The idle restrictors help fine tune the idle transition circuit before the main metering kicks in. The power valve restrictors help tune the amount of extra fuel the power valve delivers.
Thats really the main ones, but aftermarket metering blocks usually also allow changing the bleeds in the emulsion circuit.
