50+ degrees of timing @ 3100
#117215
09/08/08 12:20 PM
09/08/08 12:20 PM
Posts: 128 usa
mrmopardan
usa
Have any of you had this happen? 440 with an Mopar Mech. locked dist. curved for my application & MSD 6AL box. The initial should be 19* @ idle & 34* @ 3100 rpm. The engine runs great but the timing reads 52* @ 3100 rpm.
Is this a MSD problem? Wires seem to be connected correctly & like I said the eng. runs great. Appreciate your help.
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: 50+ degrees of timing @ 3100
[Re: ZIPPY]
#117217
09/08/08 12:36 PM
09/08/08 12:36 PM
Posts: 128 usa
mrmopardan
usa
Yes, it is a dial back timing light & in the past has proven to be very accurate.
[Re: mrmopardan]
#117218
09/08/08 12:42 PM
09/08/08 12:42 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
That's probably the issue....try a straight light that does not have the dial.
I'm not trying to say your light is inaccurate, but MSD states to not use the dial type with their ignitions. Apparently the multiple sparks freaks out the light somehow.
Rich H.
Esse Quam Videri
[Re: dgc333]
#117221
09/09/08 01:21 PM
09/09/08 01:21 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
I had a similar issue in my SB. The timing will depend on the reference the EFI will get.
I was using a locked dizzy and my initial advance was about 37š.
I donīt know how MSD reads the sigal. Thatīs why itīs too high. Ask them.
BR, Fernando
1973 Brasilian Dart E100, boosted 390"
