99 Durango rear axle width? #1172027
02/04/12 09:25 PM
02/04/12 09:25 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
How wide is a durango rear axle compared to an early 70's A body rear axle?Will it fit?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 99 Durango rear axle width? [Re: rattler] #1172028
02/05/12 10:10 AM
02/05/12 10:10 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Bump to the top. I know somebody has considered this swap. How do the widths compare?
Re: 99 Durango rear axle width? [Re: rattler] #1172029
02/05/12 10:40 AM
02/05/12 10:40 AM
scratchnfotraction Offline
when i had my 68 Dart i was looking at some of the jeep rear axles myself.sitting in traffic i thought they were really close to a bolt in.
fast forward to last weekend,i put a tape measure on my sons jeep cherokee 8 1/4 rear axle from a 94
the spring perch is same as the A-body 43" centers,they would need moved to the bottom of the tube for axle over spring but would bolt right in my 85-88 truck on the axle under the spring.
i have the A-body 8 3/4 from the dart in my 88 truck now with the 12" rims in the fenders.
from what i can tell i can bolt the jeep rear axle in my 85 and tuck 12s under it also.
i need to do some more measureing to confirnm the rim width and backset for sure.
my son just poped a dana 35 with 4.10s in his jeep on the same 43" perchs the 8 1/4 come off of...
i am junkyarding looking at some of the jeep axles now,i have not run up on a rango to measure yet but looks like it might be the 43" centers too.
I like bolt in deals and looks like I have found a way of scoreing better gears 3.73-4.10 sounds good to me
I will let you know if i run up on one I can pull a measurement off the axle flange to axle flange to see how it compairs to the width of an A-body 8 3/4
side note)i do have large brakes/green bearings which make mine a 1/2" wider by 1/4" each side..this is what i will compair it to..not A-body stock skinny 1 3/4' brake offset axles.
i would bolt this jeep axle in my 85 stepside this weekend but he has the side gears welded to the carrier for a lincon locker
I am thinking a jeep 8 1/4 with disc brakes would work also for a tub job,but the coil spring brackets need removed and perches centered and welded on.
IIRC your 57 truck has an A-body rear axle,,is it narrower than A-body specs?
what are you thinking about doing with the rango rear axle???
remember those are 6 lug axles IIRC
Re: 99 Durango rear axle width? [Re: scratchnfotraction] #1172030
02/05/12 07:52 PM
02/05/12 07:52 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you relocate the spring perches to the bottom they will bolt in, but you get stuck with that silly 6 lug bolt pattern.
Re: 99 Durango rear axle width? [Re: scratchnfotraction] #1172031
02/05/12 07:53 PM
02/05/12 07:53 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
cool post the info.. it would be nice to get a few numbers together, i have a 96 dak. would be nice to find a dirrect bolt on 5 lug from a JY..or even a late model bolt o for a dart..
Re: 99 Durango rear axle width? [Re: Dakota_Don] #1172032
02/05/12 08:37 PM
02/05/12 08:37 PM
i know I have seen a B-body 8 3/4 bolted right in a Dak..not sure if it had the perches moved.
but was slighly narrower than stock dak axle and fit a 10' rim with a 10.5 tire in the fenders(not usre if tubs were stock)
I measured the jeep axle I have from a 94 cherokee sport
43" perch centers and axle flange to axle flang was 61" with out the drum on.
anyone know the axle flange to axle flange on the A-body 8 3/4 with large brake axles?
i think the jeep axle and A-body are very close at 61' IIRC
anyone have the flange to flange measurement on a jeep axle with disc brakes??
i want one for the 85 truck as the bed is tubbed and ready for fattys ,this maybe the cheap ticket I have been looking for and disc brakes too boot
Re: 99 Durango rear axle width? [Re: scratchnfotraction] #1172033
02/05/12 10:37 PM
02/05/12 10:37 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
for some reason i wanna say my 96 dak had 63 flange to flange.. and 43 perch..
Re: 99 Durango rear axle width? [Re: Dakota_Don] #1172034
02/05/12 11:06 PM
02/05/12 11:06 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Had a brain fart, i forgot that the Durango was 6 lug. I am looking for options for another rear axle for the 72 Dart that the wife bought. It has a 7 1/4 in it now and i have plans for a 360 magnum motor for it.Around here, axles for A bodies are hard to come by.
Re: 99 Durango rear axle width? [Re: rattler] #1172035
02/05/12 11:53 PM
02/05/12 11:53 PM
I think the 94 jeep 8 1/4 would fit the bill in the A-body
and its 5 on 4.5 wbp
its already on 43" perch centers,just move them to under the tube for the car spring under axle.
8 1/4 should hold up fine in A-body with magnum SB
some 3.73s would be sweet IMO
Re: 99 Durango rear axle width? [Re: rattler] #1172036
02/06/12 12:06 AM
02/06/12 12:06 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i think u can swap to 5 lug dak axeles
Re: 99 Durango rear axle width? [Re: Dakota_Don] #1172037
02/06/12 12:11 AM
02/06/12 12:11 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i think the gen 3 axles are wider then gen 2 by 3 inches
Re: 99 Durango rear axle width? [Re: d-150] #1172038
02/06/12 12:16 AM
02/06/12 12:16 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Hey Scratch, would that jeep be a Cherokee or a Grand?
Re: 99 Durango rear axle width? [Re: rattler] #1172039
02/06/12 12:27 AM
02/06/12 12:27 AM
94 cherokee sport XJ 2x
the dana 35 4.10 gear we put in was from a 85-86 cherokee XJ 4x4-4cyl
I would use a d35 but the axle tubes/u-bolts are smaller fit but has same perch center and width,no c-clips
the 8 1/4 has 3" tubes/u-bolts and c-clip alxes 43" centers and width
I wish he had not welded up the 8 1/4 with 3.73
i will have to scratch up another one for the 85,i hope the disc brake width is the same on them.
a killer 9 1/4 from a rango would be kool,weld up the 6 stud holes and drill for 5 on 4.5
Re: 99 Durango rear axle width? [Re: rattler] #1172040
02/06/12 12:32 AM
02/06/12 12:32 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
If you look for a jeep cherokee or comanche from 86 to ?94 with the towing pakage they will usually have a dana 44 pretty strong axle . i think the grand cherokees with a v8 has a aluminum housing dana 44 also ,
Re: 99 Durango rear axle width? [Re: scratchnfotraction] #1172041
02/06/12 12:33 AM
02/06/12 12:33 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
orlando u pullit sometimes has the dak or durango 9.25 in the yard for 117.00
