Stupid 440 Cam Install Question #1172002
02/04/12 08:33 PM
02/04/12 08:33 PM
Out in Left Field, NY
bobs66440 Offline OP
After the cam and timing set is installed, what keeps the cam it place from sliding forward & back (and timing gear from rubbing on the block)? Just the timing chain tension? I assume it is self-centering and finds it's own place??
Re: Stupid 440 Cam Install Question [Re: bobs66440] #1172003
02/04/12 08:45 PM
02/04/12 08:45 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
all your big block mopars have front worm gear drive on camshaft,for itermediate shaft. when engine runs worm drive pulls cam to back of block. cam is only guna bounce the distance of drive gap, my fourspeed cars have front roller buttons on cam fronts for no bounce with high rpm shifts.
MOPAR OR NO CAR
Re: Stupid 440 Cam Install Question [Re: bobs66440] #1172004
02/04/12 09:07 PM
02/04/12 09:07 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
the cam lobes are ground with a taper that the lifter face is always presssig cam rearward, this angle also causs the lifter to rotate !
roller cams have no taper and need a button !
Re: Stupid 440 Cam Install Question [Re: calrobb2000] #1172005
02/04/12 09:29 PM
02/04/12 09:29 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
chain tensioner?
Re: Stupid 440 Cam Install Question [Re: calrobb2000] #1172006
02/04/12 09:40 PM
02/04/12 09:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
hi
Correct answer... If you use a roller cam you need a thrust button, otherwise the lobe taper takes care of thrust... But a thrust button won't hurt anything & many high performance builds run one...
Re: Stupid 440 Cam Install Question [Re: 1_WILD_RT] #1172007
02/04/12 10:40 PM
02/04/12 10:40 PM
hi
Okay, so if the cam is always being pulled toward the rear of the block, then what keeps the cam gear from running into the block?
Sorry for the ignorance, just trying to understand.
Re: Stupid 440 Cam Install Question [Re: bobs66440] #1172008
02/04/12 10:43 PM
02/04/12 10:43 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It's fine running against the block, there is not much force there, and plenty of oil.
Re: Stupid 440 Cam Install Question [Re: 1_WILD_RT] #1172009
02/04/12 11:45 PM
02/04/12 11:45 PM
hemigod426 Offline
hemigod426  Offline
hi
he said 440 the solid bushed drive holds it stable and worms in, on rear drive cams that just mesh dizzy, cams are cut with larger taper .003 so tappet pressure drives them back. yes all v8 center cams drive in on cast cams. any time you increase valve spring pressure over 300lbs open and spin high rpms you want to use torrington thrust bearing timing set and button on cam front even with cast cams.solid roller billet steel cams have no taper on lobes
MOPAR OR NO CAR
