Re: Stupid 440 Cam Install Question
[Re: bobs66440]
#1172003
02/04/12 08:45 PM
02/04/12 08:45 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
all your big block mopars have front worm gear drive on camshaft,for itermediate shaft. when engine runs worm drive pulls cam to back of block. cam is only guna bounce the distance of drive gap, my fourspeed cars have front roller buttons on cam fronts for no bounce with high rpm shifts.
MOPAR OR NO CAR
[Re: bobs66440]
#1172004
02/04/12 09:07 PM
02/04/12 09:07 PM
Posts: 1,996 s. e. pa.
calrobb2000
s. e. pa.
hi the cam lobes are ground with a taper that the lifter face is always presssig cam rearward, this angle also causs the lifter to rotate ! roller cams have no taper and need a button !
[Re: 1_WILD_RT]
#1172007
02/04/12 10:40 PM
02/04/12 10:40 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Correct answer... If you use a roller cam you need a thrust button, otherwise the lobe taper takes care of thrust... But a thrust button won't hurt anything & many high performance builds run one...
Okay, so if the cam is always being pulled toward the rear of the block, then what keeps the cam gear from running into the block?
Sorry for the ignorance, just trying to understand.
