426 hemi valve springs ID? #1171963
02/04/12 07:48 PM
02/04/12 07:48 PM
N.Y.
sixpacksteve Offline OP
N.Y.
i found a box of hemi valve springs they have a pink stripe on them.
can someone id these please? thanks
Hell Hath No Fury Like Mine
Re: 426 hemi valve springs ID? [Re: sixpacksteve] #1171964
02/05/12 12:12 PM
02/05/12 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What leads you to believe they are 426 hemi specific ? What brand are they?
Re: 426 hemi valve springs ID? [Re: sixpacksteve] #1171965
02/05/12 01:24 PM
02/05/12 01:24 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I can't remember which ones the pink stripes were. Do you have a caliper you can measure the wire with? Do they have inner springs or just dampers?
To be honest you're probably better off just taking 2 of them to a good engine shop and have them measure the pressure at installed and compressed height, and see where they coil bind, that's what matters anyway.
Sheldon
Re: 426 hemi valve springs ID? [Re: sixpacksteve] #1171966
02/05/12 01:51 PM
02/05/12 01:51 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Color coded stripe like pink means possibly a K-Motion spring ?
logan426
Re: 426 hemi valve springs ID? [Re: MLR426] #1171967
02/05/12 02:10 PM
02/05/12 02:10 PM
N.Y.
N.Y.
i should have mentioned they are in a K motion box that says K-1000 on side? possibly a roller cam?
Re: 426 hemi valve springs ID? [Re: sixpacksteve] #1171968
02/05/12 02:23 PM
02/05/12 02:23 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
ding, ding, ding, 10 points for me
K-1000 I believe are roller springs I'm not near my book for specs. Google it and it will come up, dual spring.
logan426
