Re: MOPAR 318/360 MAGNUM BLOCKS
[Re: LA360]
#1171582
02/04/12 07:18 PM
02/04/12 07:18 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Sorry - I didn't catch the R3 part. That does make a slight difference. ![](/ubbthreads/images/graemlins/thumbs.gif) I wish I hade 1... or 10.
[Re: StandOnIt]
#1171586
02/06/12 02:40 PM
02/06/12 02:40 PM
dogdays
For those who missed it, the OP gave a casting number that started with a "P". That means it is a Mopar Performance piece, not a stock block out of a pickup.
R.
[Re: moparmacka]
#1171588
02/06/12 05:55 PM
02/06/12 05:55 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
As a side note, regarding this little tidbit: Hydraulic Roller Camshafts (requires tappet retainer kit P5155275)
If you want to use that kit, try to see if it exists. Not sure what your plans are regarding lifters.
Good luck, Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: Wedgeman]
#1171590
02/09/12 03:08 AM
02/09/12 03:08 AM
Posts: 6,150 Melbourne , Australia
LA360
Buy the block through an engine builder who can sonic test it for you before they ship it over to Aus. Might cost you a little more, but atleast you will know what you are getting. You could try Brian at IMM engines in California.
Alan Jones
