water pump and timing advise for LA 360 #1171566
02/04/12 03:20 AM
02/04/12 03:20 AM
Nampa, ID
None2Slow Offline OP
Nampa, ID
I am putting together a 360 and need water pump advise. I currnetly have a new aluminum water pump. That problem is that the timing cover is from a 318 with iron pump. When I put the w/p on, the pulleys are way off. I put the old iron pump on and it all lines up. So, I need to get a new iron pump. Do I want 1 for a/c or no? Does it make a difference? Crank pulley o/d is 6.25 and the w/p pulley o/d is 6.5. This will allow the 318 timming tab to be used, but what about the marks on the balancer? What needs to be done there? All help is appreciated.
Re: water pump and timing advise for LA 360 [Re: None2Slow] #1171567
02/04/12 05:09 AM
02/04/12 05:09 AM
iron pumps are thinner but you can space the pulley back out & use slightly shorter mounting bolts. I'd find exact TDC w the ten dollar tool & make a new paint mark across the dampener & a piece of sharpened rod as a pointer. .0632683" is (1) degree i.e. 12 deg initial is 3/4" (.759") and 2&1/4" is 35.5 deg. MP (& others) have an iron pump w a pass side inlet if needed but they are pricey. EDIT and their iron pumps flow more than a parts house replacement one and I would tack weld an anticav plate on. Get one for non AC app as at least on the alum ones they have more vanes (8) which flows more & cools better
Re: water pump and timing advise for LA 360 [Re: None2Slow] #1171568
02/04/12 11:24 PM
02/04/12 11:24 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
id use the a/c pump.. but if you have a choice use the alu pump, and as mentioned before there are spacers avail.. or get the whole set up from a later LA
Re: water pump and timing advise for LA 360 [Re: Dakota_Don] #1171569
02/04/12 11:42 PM
02/04/12 11:42 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
A/c and non A/c have different diameter pulleys to spin the pump at different speeds. Mixing and matching pumps and pulleys may get you unhappy (overheating) results. If your car is non-a/c, I'd recommend a non-a/c pump. Go with a FlowCooler type pump, it will circulate water much more efficiently than a stock LA water pump (whether early iron or later aluminum)
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: water pump and timing advise for LA 360 [Re: GO_Fish] #1171570
02/06/12 01:17 AM
02/06/12 01:17 AM
Nampa, ID
Nampa, ID
Thanks so far. The motor previously had an 8 blade iron pump. When I bought the new pump I was not aware of the spacing differences. The pulley sizes I listed are what I have. I am going to be buying a new iron pump. Can you tell which pump I will need? Thanks again.
Re: water pump and timing advise for LA 360 [Re: None2Slow] #1171571
02/06/12 01:30 AM
02/06/12 01:30 AM
you need the iron pump that has the nipple on the correct side as your rad obviously. The aftermarket ones flow more. I think parts house iron ones are 6 vane/dr inlet and aftermarket ones are most likely 8 but I'm not positive on that & 8 is the way to go if avail. I agree w Stewart the Nascar water pump people that the faster the water speed the better up to a max pump speed of 5800-6000 (my max not theirs) so I overdrive the pump esp as the eng is way below 6K most of the time. dont forget the anticav plate & you can mill the FRONT of the timing cover to reduce the vane to flat clearance to .040" (including gasket thickness)
Re: water pump and timing advise for LA 360 [Re: RapidRobert] #1171572
02/06/12 06:30 AM
02/06/12 06:30 AM
Nampa, ID
Nampa, ID
Are there pics of this anti-cavitation plate?
Re: water pump and timing advise for LA 360 [Re: None2Slow] #1171573
02/06/12 10:56 AM
02/06/12 10:56 AM
Mancini may sell them but a round piece of 1/8" steel plate tack welded to the vanes then mockup & measure the distance from the plate to the recessed flat then add in the gasket thickness & decide if you want to mill the timing cover. Also in the timing cover cooling ports on each side is a casting parting line that can be removed in seconds w your die grinder. That improvement is minor but they all add up
Re: water pump and timing advise for LA 360 [Re: RapidRobert] #1171574
02/06/12 11:38 AM
02/06/12 11:38 AM
Andrewh Offline
Andrewh  Offline
first lets be clear. the 6 vane is an a/c wp.
8 vane is the non-ac pump.
the a/c pump spins faster due to the pulley size being smaller.
next, I was pretty sure the inlet changes sides when you go for the newer aluminum vs the older cast iron.
did you find an aluminum that was the same side?
Re: water pump and timing advise for LA 360 [Re: Andrewh] #1171575
02/06/12 02:35 PM
02/06/12 02:35 PM
Nampa, ID
Nampa, ID
That's the other reason I need to go back to the iron pump. The nice, pretty alum pump inlet is on wrong side. Its a new GMB pump if you know anybody looking.
