Re: F-body brake up grade?
[Re: rarefish]
#1171277
02/03/12 08:30 PM
02/03/12 08:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The 11.75" rotor with corresponding caliper adapter works great. Cordobas are good donors for both and the adapter is compatible with the F body calipers.
I've run this setup on several A bodies, an M body and a 64 300 I converted to discs. Also on my 38 Plymouth (that was an entire front suspension swap though).
